[Geoserver-devel] Multithreading Catalog Builder?
Hello,
I’m trying to publish a large amount of layers using the CatalogBuilder instead of REST but this effort takes too long.
I’ve been publishing layers using the CatalogBuilder as such:
CatalogBuilder builder = new CatalogBuilder(catalog);
CoverageStoreInfo info = catalog.getCoverageStoreByName(storeName);
builder.setStore(info);
CoverageInfo ci = builder.buildCoverage(coverageName);
LayerInfo layer = builder.buildLayer(ci);
layer.setResource(ci);
catalog.add(ci);
catalog.add(layer);
I’ve read that the CatalogBuilder is not thread safe, is there a better way to programmatically publish a large amount of layers in geoserver without the REST API?
Best,
Sylvia
On Fri, Jan 9, 2015 at 4:26 PM, Sylvia Charchut <
Sylvia.Charchut@anonymised.com> wrote:
Hello,
catalog.add(ci);
catalog.add(layer);
The problem is not much that the CatalogBuilder is not thread safe, it's
that the Catalog itself is not thread safe,
at least the default one.
The JDBC based one, contained in a community module, might be, but I'm not
100% sure about it
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I found a lot of the issues take place in the Catalog “ResourcePool”. The GeoServer REST API has a few hacks to try and make interacting with Catalolog+ResourcePool thread safe - but it is really the wrong spot.
Jody
On 9 January 2015 at 07:37, Andrea Aime <andrea.aime@anonymised.com> wrote:
Dive into the World of Parallel Programming! The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net
Geoserver-devel mailing list
Jody Garnett
On Fri, Jan 9, 2015 at 4:26 PM, Sylvia Charchut <Sylvia.Charchut@anonymised.com> wrote:
Hello,
catalog.add(ci);
catalog.add(layer);
The problem is not much that the CatalogBuilder is not thread safe, it’s that the Catalog itself is not thread safe,
The JDBC based one, contained in a community module, might be, but I’m not 100% sure about it
Ing. Andrea Aime
@geowolf
Technical Lead
