Dear all,
I’m proposing the addition of a new cog community module on GeoServer.
Where cog-> COG means Cloud Optimized GeoTIFF, a regular GeoTIFF file, aimed at being hosted on a file server, whose internal organization is friendly for consumption by clients issuing GET Byte range requests.
The module will be mainly based on new imageio-ext readers/streams supporting these Byte Range requests.
It will contain new UI sections extending the GeoTIFF format panel to configure a (COG)eoTiff Dataset, as well as additional instructions and configuration parameters to setup an ImageMosaic on top of an index referring to COG granules.
Finally it will add all the additional dependencies needed to support those new capabilities, not being part of the standard GeoServer war.
The related GeoServer JIRA.
https://osgeo-org.atlassian.net/browse/GEOS-9767
Related GeoTools JIRA and PRs (still in draft state)
GeoTIFF:
https://osgeo-org.atlassian.net/browse/GEOT-6715
https://github.com/geotools/geotools/pull/3169
ImageMosaic:
https://osgeo-org.atlassian.net/browse/GEOT-6716
https://github.com/geotools/geotools/pull/3173
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
