[Geoserver-devel] New community module "datadir-catalog-loader"
Hi, list,
There’s an optimized data-directory-specific catalog and config loader plugin developed under geoserver-cloud’s code base that we’d like to contribute upstream as a community module.
Its goal is to improve the startup time of GeoServer when configured with a data directory that has thousands of layers, stores, etc., and config objects such as workspace services and settings.
On my laptop’s SSD, running off a cold disk cache, for a data-dir with 100K layers over 100 workspaces, the performance improvement is ~8.5 seconds instead of ~44.5 seconds, with 2.23.1 as a baseline.
But the most important difference is when you need to load the data dir from a shared drive, especially NFS, where it regularly takes over 40 minutes, and with this plugin around 4 minutes.
Hence I’m asking the PSC for permission to push this plugin under community/datadir-catalog-loader
Here’s a PR for your reference.
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Gabriel Roldán
Geospatial Developer
Gabriel Roldán
+1, thanks for sharing!
camptocamp
Gabriel Roldán
Gabriel Roldán
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Thanks Andrea.
Sorry guys if eventually an exactly equal message arrives from my @anonymised.com account, I initially sent it from there but it wasn’t coming through for some reason.
camptocamp
Gabriel Roldán
Gabriel Roldán
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Gabriel Roldán
+1
-Jukka Rahkonen-
Lähettäjä: Gabriel Roldan <gabriel.roldan@…403…>
Lähetetty: lauantai 1. heinäkuuta 2023 17.25
Vastaanottaja: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: [Geoserver-devel] New community module “datadir-catalog-loader”
Hi, list,
camptocamp
Gabriel Roldán
Gabriel Roldán
Hi Gabe,
I see that it is not documented in Community modules — GeoServer 2.27.x User Manual. Is there some documentation that you can provide (in absolutely any format), and I will see about adding it to increase the visibility of your contribution.
Peter
Hi Pete,
sure, let me write something up and issue a pr.
brb
Hi Pete,
there you go: Add documentation for the DataDirectory Catalog Loader community module by groldan · Pull Request #8144 · geoserver/geoserver · GitHub
Gabe
