Hello All,
As discussed in last week’s PMC meeting, I have obtained approval to donate Boundless’s fgdb module to the GeoServer community.
As such, I would like to request permission to add this as a new community module.
The fgdb module adds a standalone datastore supporting the FileGeoDataBase format (backed by OGR/GDAL) and an Importer format to provide FileGDB support for the GeoServer importer extension.
Torben
Hi Torben,
thanks for the follow up!
The interesting bit to me is the importer integration. About the datastore, I see a factory but not a UI,
while the generic OGR store has now one with file chooser (not mandatory to choose a file):
https://github.com/geoserver/geoserver/blob/master/doc/en/user/source/community/ogr-store/index.rst
Wondering, what about just keeping the importer bit, with a tiny rewiring to make it use the OGR store
directly? Or would that be a problem for backwards compatibility in the suite?
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I see no problem with rewiring the store to use the OGR store directly, I’ll do that when I move it over.
Regarding the OGR UI, I assume you are referring to the one from the web-ogr community module?
Since that module is just UI, I’ll just have the modified fgdb depend on the GeoTools OGR store, leaving the UI module as optional.
Torben
On Mon, Feb 25, 2019 at 9:54 AM Andrea Aime <andrea.aime@anonymised.com68…> wrote:
Hi Torben,
On Mon, Feb 25, 2019 at 6:20 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hello All,
Torben
Geoserver-devel mailing list
Great
Yes
Indeed it is pure UI, so you can depend on the OGR store directly
Initial module import here: https://github.com/geoserver/geoserver/pull/3393
It compiles, but I haven’t tested if it actually works yet (I discovered that I don’t actually have a local GDAL that includes the JNI bindings).
I’m going to try and track down a version of GDAL for Mac that has what I need and see if I can test it out, but for now, the code has at least been donated to GeoServer.
Torben
On Mon, Feb 25, 2019 at 10:11 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Feb 25, 2019 at 7:08 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Great
Yes
