I’d like to add a new community module for the GeoServer ACL plugin.
The source code for this plugin resides on the geoserver-acl project code base, where it’s tested against the stable, development, and maintenance versions of GeoServer.
This community module hence only packages up the required jars to be installed as usual, and runs a Testcontainers based integration test suite, using the geoservercloud/geoserver-acl Docker image for the dependency version defined in this project’s pom.xml.
Gabriel
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Gabriel Roldán
Geospatial Developer
