Dear all,
I’m writing to inform about the creation of the new geoserver community module gsr.
The module comes as a result of the import of the gsr plugin (https://github.com/geosolutions-it/gsr), and provides
an ArcGIS REST compatibility API. According to the rules for module contribution (https://github.com/geoserver/geoserver/wiki/GSIP-186 ) ,
its license is compatible with geoserver, since it is a GPL 2.0 too.
Here you can find the pull request https://github.com/geoserver/geoserver/pull/4137.
Best regards,
Marco Volpini
+1
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Tue, Mar 24, 2020 at 10:12 AM Marco Volpini
<marco.volpini@anonymised.com> wrote:
Dear all,
I'm writing to inform about the creation of the new geoserver community module gsr.
Best regards,
Marco Volpini
Geoserver-devel mailing list
I had a look, while community modules are not subject to extensive review (until ready to be an extension) the documentation and code examples need some work before they can be incorporated.
As an example This module is GeoServices REST API, and we should be careful to handle ESRI and ArcGIS trademarks in the docs, and examples should use the open source libraries at https://esri.github.io/ (rather than the arcgis content which is under license).
Jody Garnett
Hi Jody,
my apologies for the lack of feedback.
I’m working with Marco on this one, thank you for your comments, we will follow up on your review shortly.
Best regards,
Nuno Oliveira
Jody Garnett
+1, good to see this module getting some use again.
Torben
On Tue, Mar 24, 2020 at 2:12 AM Marco Volpini <marco.volpini@anonymised.com> wrote:
Dear all,
Best regards,
Marco Volpini
