I’d like to propose a new community module, importer-jdbc… yeah, the name is a dead giveaway,
the idea is to store the status of imports in a relational database (will likely use a JDBC data store
to back it, eat your own dogfood style).
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Seems like a good idea.
Is the import database intended to be persistent between GeoServer restarts (I would assume so)? I mostly ask because the default in-memory import status storage isn’t, so there may have been assumptions made around this (e.g. not handling large import histories well).
I think persistent storage of import status would be useful, as long as it doesn’t cause problems elsewhere.
Torben
On Tue, Oct 29, 2019 at 4:46 AM Andrea Aime <andrea.aime@anonymised.com…1268…> wrote:
Geoserver-devel mailing list
Yes it is.
Well it starts as a community module, so low expectations… but yes, eventually we’ll have to handle cleaning up
the state of old imports, if the existing code is not doing that already
