Dear devs,
presenting here a new community plugin. PR available here:
https://github.com/geoserver/geoserver/pull/7474
The Features Autopopulate plug-in listens to transactions (so far only issued by WFS), and autopopulates the feature type attributes according to the values retrieved from the properties file.
The plugin uses a custom TransactionCallback that alters the insert/update WFS-T operations, forcing in specific values into them, based on configuration files.
To support configuration for multiple layers, the easiest thing is to place a configuration, file in the directories of the layers themselves, pretty much like the featureinfo templates.
A “transactionCustomizer.properties” file that contains a set of names and CQL expressions
e.g.:
UTENTE=env('GSUSER') # this will be replaced with the current user see @EnviromentInjectionCallback
AGGIORNAMENTO=now() # this will be replaced with the current date
To keep things simple, the expressions will just use environment variables, but not see the other values provided in the update/insert, and will not be differentiated by insert/update cases
Alessio Fabiani
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
mob: +39 331 6233686
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
