[Geoserver-devel] new shapefile dataStore and featureType
Hello,
I installed to geoserver and after testing all the functionnalies 'as it',
I tried to add new files (shapefile format) to be served via geoserver.
My configuration
Windows XP, Geoserver 1.2.3, JRE 1.4.2_04
What I want to do
I want to add a new featureType based on shapefile
What I did
I copy my folder containing (communes.dbf, communes.shp, communes.shx) into :
- C:\Program Files\Apache Software Foundation\Tomcat
5.0\webapps\geoserver\data\featureTypes
I define a new Datastore named "communes_shapefile" with the following url :
- file:data/featureTypes/communes/communes.shp
I click on 'apply'
I click on 'save'
As soon as I click on 'save', my folder 'communes' with the 3 files are
deleted ???
If I don't click on the button 'save' and if I create the featureType
'commune' instead, as soon as I click on 'apply' and 'save', my folder
'communes' with the 3 files are deleted and a new folder
'communes_shapefiles_communes' is created with the file info.xml inside
Where am I wrong ?
Jérémy DE ROYER
You know, I've had reports of this bug before, and tried to reproduce it
before 1.2.3, and wasn't able to. But I was also in a rush to get a
bunch of stuff in in time, so I didn't try super hard. I'll try again,
your report is more detailed than the last one I had, see:
http://jira.codehaus.org/browse/GEOS-221 I just moved it up to
'critical' for the next release for you. One question, if you name the
folder where you initially copy the shapefiles
'communes_shapefiles_communes' instead of 'communes' then does it still
do the same thing? It's definitely not you doing anything wrong, it is
a bug, that I'll work to get fixed for 1.2.3
Chris
Quoting Jérémy DE ROYER <jeremy.deroyer@anonymised.com>:
Hello,
it',
geoserver.
My configuration
What I want to do
What I did
following url :
I click on 'apply'
I click on 'save'
are
deleted ???
folder
inside
Where am I wrong ?
Jérémy DE ROYER
This SF.net email is sponsored by: IT Product Guide on
ITManagersJournal
Use IT products in your business? Tell us what you think of them.
Give us
Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find
out more
http://productguide.itmanagersjournal.com/guidepromo.tmpl
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
A)
If I name my folder, my shapefiles and my dataStore
'communes_shapefile_communes', it does the same, except that the new
folder is named communes_shapefiles_communes_shapefile_communes (;-).
If I name my folder 'communes_shapefile_communes', my shapefiles
'communes' and my dataStore 'communes', the new empty folder is named
'communes_communes'.
BUT If I define the dataStore, click on apply and save, my new empty foler
appears.
AND I copy my folder again with the rigth files inside, it works !
The bug seemes to come from the dataStore definition...
B)
If I name my folder and my files 'communes'
If I name my dataStore 'communes_shapefile' that point to communes, when I
apply and save, I get a new empty foler named
'communes_shapefile_communes'.
If I copy my old folder 'communes' back and If I define my featureType
'communes', I get the new emplty foler 'communes_shapefile_communes'.
BUT if I copy my old folder 'communes' back (again). It works !... 'til I
click on 'save' and 'appy'.
I hope it may help you.
Jérémy
Chris
Hello,
it',
geoserver.
My configuration
What I want to do
What I did
following url :
I click on 'apply'
I click on 'save'
are
deleted ???
folder
inside
Where am I wrong ?
Jérémy DE ROYER
ITManagersJournal
Give us
out more
