[Geoserver-devel] Nil and nillable
I’m working on fixing compliance with the WFS 2.0 CITE tests and stubled into something … intersting?
Our WFS 2.0 schemas, output of DescribeFeatureType, claim there are nillable properties:
xsd:complexContent
<xsd:extension base=“gml:AbstractFeatureType”>
xsd:sequence
<xsd:element maxOccurs=“1” minOccurs=“0” name=“multiPointProperty” nillable=“true” type=“gml:MultiPointPropertyType”/>
<xsd:element maxOccurs=“1” minOccurs=“0” name=“multiCurveProperty” nillable=“true” type=“gml:MultiCurvePropertyType”/>
<xsd:element maxOccurs=“1” minOccurs=“0” name=“multiSurfaceProperty” nillable=“true” type=“gml:MultiSurfacePropertyType”/>
<xsd:element maxOccurs=“1” minOccurs=“1” name=“doubleProperty” nillable=“false” type=“xsd:double”/>
<xsd:element maxOccurs=“1” minOccurs=“0” name=“intRangeProperty” nillable=“true” type=“xsd:string”/>
<xsd:element maxOccurs=“1” minOccurs=“1” name=“strProperty” nillable=“false” type=“xsd:string”/>
<xsd:element maxOccurs=“1” minOccurs=“1” name=“featureCode” nillable=“false” type=“xsd:string”/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
and then the CITE tests assumes it can run PropertyIsNil filters on them… which would not even parse, but I have a simple fix for that locally
(see https://osgeo-org.atlassian.net/browse/GEOS-6033 for the report about no support for parsing that).
Now, with the fix the request goes through and then the CITE test fail because they do expect to find an empty element with
xsi:nil=‘true’, while GeoServer’s code does not emit the element at all.
There is also a symmetric ticket open on the write side here:
https://osgeo-org.atlassian.net/browse/GEOS-3126
Wondering, given our current behavior, wouldn’t it be better to not add the nillable attribute in the schema?
The notion that an element might be missing is already present in minOccurs=“0” no?
It seems that if we keep the schema as is today, then we’d have to change the way we encode the GML outputs (to add the element with
nil and eventually nil reason instead of omitting them) and the way we parse inputs for transaction (to handle the same representation in input)
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
quick follow up, I just tried removing nillable and then was met with this error by CITE tests:
java.lang.AssertionError: Unable to test required capability: PropertyIsNil. No feature type for which instances exist has nillable properties.
Hmm… given CITE tests for WFS 2.0 do not need a specific dataset I’m not sure that’s a valid failure, but ok, I’ll inquire with OGC
On Wed, Nov 22, 2017 at 5:35 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
xsd:complexContent
xsd:sequence
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
