[Geoserver-devel] Omitting service=wfs from a KVP WFS 2.0 request has unpredictable results
I was doing some testing with WFS GetFeature requests, and ran into some rather startling behaviour.
First of all, omitting the “service=wfs” parameter from a KVP-encoded request generally works just fine, as long as you are using the WFS virtual service endpoint. However, sometimes it doesn’t. All testing is done with a GeoServer 2.10.2 installation with no extensions:
With service=wfs:
http://localhost:8080/geoserver/wfs?service=wfs&request=GetFeature&typenames=sf:roads&version=2.0.0
returns all property values for all features in sf:roads
http://localhost:8080/geoserver/wfs?service=wfs&request=GetFeature&typenames=sf:roads&version=2.0.0&propertyname=
http://localhost:8080/geoserver/wfs?service=wfs&request=GetFeature&typenames=sf:roads&version=2.0.0&propertyname=*
http://localhost:8080/geoserver/wfs?service=wfs&request=GetFeature&typenames=sf:roads&version=2.0.0&propertyname=cat
returns all values for cat property for all features in sf:roads
http://localhost:8080/geoserver/wfs?service=wfs&request=GetFeature&typenames=sf:roads&version=2.0.0&propertyname=cat,label
returns all values for cat and label properties for all features in sf:roads
Without service=wfs:
http://localhost:8080/geoserver/wfs?request=GetFeature&typenames=sf:roads&version=2.0.0
http://localhost:8080/geoserver/wfs?request=GetFeature&typenames=sf:roads&version=2.0.0&propertyname=
<ows:Exception exceptionCode=“NoApplicableCode”>
ows:ExceptionTextjava.lang.NullPointerException</ows:ExceptionText>
</ows:Exception>
http://localhost:8080/geoserver/wfs?request=GetFeature&typenames=sf:roads&version=2.0.0&propertyname=*
</ows:Exception>
http://localhost:8080/geoserver/wfs?request=GetFeature&typenames=sf:roads&version=2.0.0&propertyname=cat
ows:ExceptionText
java.lang.ClassCastException: java.lang.String cannot be cast to java.util.Collection java.lang.String cannot be cast to java.util.Collection
</ows:Exception>
http://localhost:8080/geoserver/wfs?request=GetFeature&typenames=sf:roads&version=2.0.0&propertyname=cat,label
ows:ExceptionText
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Index: 0, Size: 0
</ows:Exception>
Given that all of the above is not actually valid according to the WFS 2.0 specification (the propertyname parameter is not part of the 2.0 spec), this is slightly less problematic. However since we still provide this functionality, some amount of consistency would be good.
Given the errors observed when service=wfs is omitted, it might be best to explicitly throw an error instead when service is not included in the KVP.
Does anyone else have any insight here?
Torben
On Fri, Mar 17, 2017 at 12:23 AM, Torben Barsballe <
We've been down this road already with the version number, also required,
not mandated by GeoServer in its default configuration, and causing
occasional failures
in kvp parsing when omitted.
I did not check, but I'd guess that service omission might be the same.
Mandating it out of the box is a no go for simple backwards compatibility
issues,
and also because it is going to break existing endpoints like the wms
reflector, kml reflector and animator which normally miss both service and
version
(incidentally, I'm also building the
sort-of-rest-but-not-quite-and-more-kvp-like OpenSearch service on the same
premise as the reflectors,
that the service and method can be put in the path and version is not
required).
I've been down this road in the past for "version", what I found out is
that the kvp parsing should have clear service and version before the
kvpparsers are called, right
now it's a mixed bag, kvp parser get what's in the kvp, if it's available,
and then some code later figures out service and version if they were
missing... but
at that point the dispatcher might have used the wrong kvp parsers.
I did prepare a pull request in my spare time to address this, but Justin
requested me to run the cite tests offline and I never had time (or to be
fair, the inclination
to do so on a weekend);
My take: if you want to try and resurrect that patch, align it with today's
GeoServer, and make it built, I'd say go ahead and commit it on master,
and we'll see what the ares CITE jobs think of it. Our CITE compliance is
in quite some disarray anyways, it's not going to be a big deal if
master is not compliant with our outdated version of the tests for a night
or two imho
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks for the link to the PR Andrea (and the explanation of what is going on here). I’ll try and make some time to get that working with the current geoserver.
Torben
On Fri, Mar 17, 2017 at 12:30 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Mar 17, 2017 at 12:23 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
We’ve been down this road already with the version number, also required, not mandated by GeoServer in its default configuration, and causing occasional failures
I did not check, but I’d guess that service omission might be the same. Mandating it out of the box is a no go for simple backwards compatibility issues,
and also because it is going to break existing endpoints like the wms reflector, kml reflector and animator which normally miss both service and version
(incidentally, I’m also building the sort-of-rest-but-not-quite-and-more-kvp-like OpenSearch service on the same premise as the reflectors,
that the service and method can be put in the path and version is not required).
I’ve been down this road in the past for “version”, what I found out is that the kvp parsing should have clear service and version before the kvpparsers are called, right
now it’s a mixed bag, kvp parser get what’s in the kvp, if it’s available, and then some code later figures out service and version if they were missing… but
I did prepare a pull request in my spare time to address this, but Justin requested me to run the cite tests offline and I never had time (or to be fair, the inclination
https://github.com/geoserver/geoserver/pull/574
My take: if you want to try and resurrect that patch, align it with today’s GeoServer, and make it built, I’d say go ahead and commit it on master,
and we’ll see what the ares CITE jobs think of it. Our CITE compliance is in quite some disarray anyways, it’s not going to be a big deal if
master is not compliant with our outdated version of the tests for a night or two imho
Ing. Andrea Aime
@geowolf
Technical Lead
