[Geoserver-devel] On track for beta2 release friday
The last tests are being perform this week (shout out to Niels, Lugi, Alessandro, Damiano for the manual testing ). As I understand it security-cas is the last scheduled test.
I would like to start this release on Friday - please shout out if you are trying to get a pull request in before then.
Jody Garnett
Ciao Jody,
the tests that we are looking into performing are:
- CAS
- Manual Test with GeoServer manager
I am not sure we will make on time for this friday, I am not sure this
is a showstopper as we will make them anyway even if we do beta2 on
fri. If anything comes up will fix afterwards.
Opinions?
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Apr 12, 2016 at 8:18 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers
of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-devel mailing list
I have a tiny usability PR for the bin.zip {startup,shutdown}.sh (detect Java from PATH is JAVA_HOME not set) but have no feedback and need to know if it works on MacOS. It was in response to a community PR that I thought might break MacOS:
Detect Java runtime from JAVA_HOME or PATH
https://github.com/geoserver/geoserver/pull/1553
If I merge this today and kick the nightly, those with MacOS (and other Linux) could check to see if the bin.zip still starts. I think it would be a nice convenience improvement in 2.9.
The PR does not affect the Windows startup.bat; does anyone use startup.sh on Windows? Windows can now run user mode Ubuntu binaries:
https://msdn.microsoft.com/en-us/commandline/wsl/about
https://blogs.windows.com/buildingapps/2016/03/30/run-bash-on-ubuntu-on-windows/
Kind regards,
Ben.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Agreed it should not be a show stopper, beta is needed as we have installer / release issues to find.
On Tue, Apr 12, 2016 at 2:17 AM Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Jody,
  • CAS
  • Manual Test with GeoServer manager
Opinions?
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Jody Garnett
of
