Hi! What's the status with Open Source ArcSDE? Could I help in any way with that? I'm doing a coursework on open source in the university and have used Geoserver before. Thanks, Anna
Hi Anna,
what exactly do you mean by "Open Source ArcSDE"?
Do you mean the GeoTools ArcSDE plugin and the GeoServer extension
that uses it? because afaik there's no such a thing as an Open Source
ArcSDE?
Or do you rather mean this old write up from Chris Holmes
<http://geoserver.org/display/GEOS/Open+Source+ArcSDE>
On Thu, Apr 12, 2012 at 6:03 AM, Anna Kamunen <Anna.Kamunen@anonymised.com> wrote:
have used Geoserver before. Thanks, Anna------------------------------------------------------------------------------
For Developers, A Lot Can Happen In A Second.
Boundary is the first to Know...and Tell You.
Monitor Your Applications in Ultra-Fine Resolution. Try it FREE!
http://p.sf.net/sfu/Boundary-d2dvs2
Geoserver-devel mailing list
Gabriel Roldan
OpenGeo - http://opengeo.org
btw, whatever you refer to, I'm sure we'll be glad to get some help.
All and every help is appreciated on these projects. It just wasn't
clear to me what your interests are.
Gabriel
On Fri, Apr 13, 2012 at 5:38 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hi Anna,
ArcSDE?
<http://geoserver.org/display/GEOS/Open+Source+ArcSDE>On Thu, Apr 12, 2012 at 6:03 AM, Anna Kamunen <Anna.Kamunen@anonymised.com> wrote:
https://lists.sourceforge.net/lists/listinfo/geoserver-devel--
Gabriel Roldan
Gabriel Roldan
Hi, thanks for the reply!
Yes, I referred to the draft by Holmes, I know it's old. Anything more
current I could join in?
- Anna
Quoting Gabriel Roldan <groldan@anonymised.com>:
Hi Anna,
ArcSDE?
Gabriel Roldan
