[Geoserver-devel] Optional caching of WMS GetMap remote style through SLD parameter
I would like to introduce an optional cache for styles fetched by GeoServer through the WMS GetMap SLD parameter, to optimize the retrieval of dinamically generated SLD files that could require some time to be remotely generated.
Any preference about the caching technology?
I used guava caches in the past to implement authentication caches. Any concern in using a similar approach here?
Many thanks.
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Mauro,
since some bits of HTTP caching headers support would be useful (if not mandatory?) what about using
the one built into commons httpclient? (maybe via some customization)
https://hc.apache.org/httpcomponents-client-ga/tutorial/html/caching.html
On Mon, Jul 2, 2018 at 12:55 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com…> wrote:
Many thanks.
Mauro Bartolomeoli
@mauro_bart
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
good idea, I will experiment a bit with that, thanks.
Mauro
On Mon, Jul 2, 2018 at 12:55 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Many thanks.
Mauro Bartolomeoli
@mauro_bart
Technical Lead
Mauro Bartolomeoli
@mauro_bart
Technical Lead
using the caching httpclient would require upgrading httpclient to version 4.1 (minimum). We currently use 3.1. Any concern with the eventual upgrade?
The alternative option of using guava-cache would not require any library update.
Mauro
Many thanks.
Mauro Bartolomeoli
@mauro_bart
Technical Lead
Mauro Bartolomeoli
@mauro_bart
Technical Lead
On Fri, Jul 6, 2018 at 9:52 AM, Mauro Bartolomeoli <
Personally I would welcome the upgrade, even if just in that area, since we
have to eventually switch to it.
You just need to double check that the two versions of httpclient can live
toghether, if we don't have resources to do
a full switch (think geotools wms/wmts/wfs cascading, standalone gwc
commnication with wms services, wps
access to remote resources, and so on)
------------------------------------------------------- *Con riferimento
telephone or e-mail.*
It should be doable. Version 4.x looks like a different beast (renamed to httpcomponents, a new package and probably some differences in the APIs), so they should not conflict.
Mauro
On Fri, Jul 6, 2018 at 9:52 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com…1268…> wrote:
Personally I would welcome the upgrade, even if just in that area, since we have to eventually switch to it.
You just need to double check that the two versions of httpclient can live toghether, if we don’t have resources to do
a full switch (think geotools wms/wmts/wfs cascading, standalone gwc commnication with wms services, wps
Mauro Bartolomeoli
@mauro_bart
Technical Lead
Ah, in case it’s of any use, this ticket points to a branch that has a start of switch to httpclient4 for
geotools:
https://osgeo-org.atlassian.net/browse/GEOT-5859
At the very least, you should find “patterns” for the switch to happen
On Fri, Jul 6, 2018 at 10:03 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Mauro
Il giorno ven 6 lug 2018 alle ore 10:00 Andrea Aime <andrea.aime@anonymised.com> ha scritto:
Mauro Bartolomeoli
@mauro_bart
Technical Lead
On Fri, Jul 6, 2018 at 9:52 AM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.comsolutions.it> wrote:
