hi;
i would like to integrate oscache in my geoserver, i modified the featureTypes/…/info.xml files and added the oscache.properties, the jar.
which other files must i modify?
Cordialement
Ilyes JRAD
Daleelteq
Tél. : +216 71 960 400-Fax: +216 71 960 554
GSM 97 202 226
Immeuble Yugurtha, angle rue lac Léman et rue des lacs Mazuries
Les Berges du lac 1053 - Tunis, Tunisie http://www.daleelteq.com
I have never actually done this myself but looks like you have to modify
the web.xml file and you should be good to go.
-Justin
ilyes jrad wrote:
hi;
featureTypes/.../info.xml files and added the oscache.properties, the jar.
Cordialement
Ilyes JRAD
Daleelteq
GSM 97 202 226
Les Berges du lac 1053 - Tunis, Tunisie http://www.daleelteq.com !DSPAM:4007,46ef689d115221137850744!
Defy all challenges. Microsoft(R) Visual Studio 2005. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
-Justin
ilyes jrad wrote:
hi;
Cordialement
Ilyes JRAD
Daleelteq
GSM 97 202 226
Have you seen this? http://docs.codehaus.org/display/GEOSDOC/Caching
-Justin
ilyes jrad wrote:
hi;
Cordialement
Ilyes JRAD
Daleelteq
GSM 97 202 226
