After updating trunk this morning and trying to build, I see a test failure in main/org.geoserver.feature.PagingFeatureSourceTest. It was my understanding that the paging featuresource wrapper would be removed once GeoTools supported paged requests; so why is this still here?
(PS: I talked to Andrea about the failure itself and he was unable to reproduce it, if anyone could provide some insight I've pasted the trace at http://pastebin.ca/1046011)
-David
It was my fault not to remove the wrapper, going to do so now
Thanks for pointing it out dave.
Gabriel
-David
!DSPAM:4045,4851320a324273327367457!
Go ahead and remove it. but I doubt that it was the cause of the problem.
Gabriel
-David
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-devel mailing list
!DSPAM:4007,4851334c3647082231907!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Not really sure if it was or not. Yet I removed it and the build is back to
normal, didn't check if it was due to this or not really
Gabriel
> Gabriel
>> -David
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Since the last few lines of the error stack trace indicated some problems in geotools code, I tried reverting all changes made today in geotools (svn up -r{$(date --iso-8601)}) and rebuilding, the error went away for me as well.
I didn't mean to imply that I thought the wrapper was causing problems, just that I discovered it because problems existed.
-David
Not really sure if it was or not. Yet I removed it and the build is back to normal, didn't check if it was due to this or not really
Gabriel
Gabriel
-David
!DSPAM:4040,48516308131445210051143!
no ofense whatsoever dave, thanks for pointing out it was still there again.
Gabriel
-David
>> problem.
> Cheers,
> Gabriel
>>> Gabriel
>>>> here?
>>>> -David
>>>-- Check out the new SourceForge.net Marketplace.
>>> _______________________________________________
!DSPAM:4045,48516467137701431913854!
