for your 130k diff reviewing pleasure you can find the patch for trunk
attached here:
http://jira.codehaus.org/secure/ManageAttachments.jspa?id=96855
I've tested it a bit, seems to work fine, all tests are passing
and running GS behind a proxy works too (minus the authentication
in the GUI, but that's a separate issue... and something I think
we've already seen in 1.7.x)
Andrea Aime
OpenGeo - http://opengeo.org
Big patch no doubt
Just went through it and it looks really good. Much cleaner result.
One question I have is about the request base url. It seems a lot of code before was proxifying the base url as soon as it was grabbed from the request. But now the pattern is to just build/mangle the url only when it needs to be encoded. Nice change, just those who are writing service code need to keep the paradigm shift in mind.
I made some comments on the issue.
-Justin
Andrea Aime wrote:
attached here:
Justin Deoliveira
