[Geoserver-devel] per layer security module
Hi Francesco,
I noticed that you moved your module from community into web2. Technically this is against the rules, as it is a commit to a module of which you are not the maintainer. However I do realize that this is a sub module of web, so technically no existing code was changed.
Also, this change was done without any consulting of the developers list or of the module maintainer. This is also a no no.
I am curious. Why did you decide to move the module to web2? The only change i was excepting to see to web2 was a profile added to the pom which added a dependency on the module.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
i thinking that this are possibile for the community submodule. And for this i have added the module on the web2.
If this is an error, i remove immetiatly the module, and i move in the community root.
I thinking that the perLayer Security User Interface was a module of the web2.
Sorry,
2008/12/19 Justin Deoliveira <jdeolive@anonymised.com>
Hi Francesco,
-Justin
Justin Deoliveira
Francesco Izzi
geoSDI - NSDI
Responsabile Sviluppo Software
C.da Loja
85050 Tito Scalo - POTENZA (PZ)
Italia
phone: +39 0971427305
fax: +39 0971 427271
mob: +39 3402640314
http://geosdi.nsdi.it
Hi Francesco,
No problem. It is understandable since web2 is itself a community module. I think that after the per layer security module is more complete that we can move it to web2.
Others may disagree with me and want to see the new module inside of web2. It would be nice to have a second opinion.
-Justin
Francesco Izzi wrote:
Hi Justin,
Sorry,
2008/12/19 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
    Hi Francesco,
    -Justin
    -- Justin Deoliveira
Francesco Izzi
geoSDI - NSDI
C.da Loja
Italia
mob: +39 3402640314
Geoserver-devel mailing list
Justin Deoliveira
Hi Justin,
I had thought that the per layer security ui it had to be inside the web2 module but mistook.
are in agreement when the per layer security module is mature we can move it to web2.
For this i wont some suggestion for the module dependencies and how test in the web2 interface.
Thanks Justin
Hi Francesco,
-Justin
Hi Justin,
Sorry,
2008/12/19 Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>
Hi Francesco,
-Justin
– Justin Deoliveira
Francesco Izzi
geoSDI - NSDI
C.da Loja
Italia
mob: +39 3402640314
Justin Deoliveira
Francesco Izzi
geoSDI - NSDI
C.da Loja
Italia
mob: +39 3402640314
