[Geoserver-devel] Platform independent binary is broken on main
I’ve just created https://osgeo-org.atlassian.net/browse/GEOS-11224 - basically you can’t have .. in the data directory path any longer, which we do by default, I’m guessing this is caused by one of the recent security fixes, does it ring a bell with anyone?
Ian
Ian Turton
The URL check normalizes relative paths before checking; so that should be fixable.
Ian Turton
Likely starting GeoServer form inside the “bin” folder?
It’s something I never do.
I’ve tried with a 2.24.1 I had handy and:
  • Starting as usual from the top, calling “bin/startup.sh”, no problem
  • Getting into “bin” and starting from there… boom! From the logs:
    GEOSERVER DATA DIR is /home/aaime/devel/gs_releases/geoserver-2.24.1/bin/../data_dir
---- Debugging information ----
cause-exception : java.lang.IllegalArgumentException
cause-message : Contains invalid ‘..’ path: /home/aaime/devel/gs_releases/geoserver-2.24.1/bin/../data_dir
class : org.geoserver.catalog.impl.DataStoreInfoImpl
required-type : org.geoserver.catalog.impl.DataStoreInfoImpl
converter-type : org.geoserver.config.util.XStreamPersister$StoreInfoConverter
line number : 17
version : 2.24.1
Ian Turton
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
I tested also, and determined that the only way to get that path was to start from the bin folder.
However that is working for me, testing geoserver-main-latest-bin download. I added some notes to the ticket also.
I am assuming URLChecks are being enabled by default on main.
Ian do you have any more information about your setup?
Jody Garnett
Ian Turton
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
I was indeed in bin to run start.sh - it’s Java 17, Ubuntu 22.04 usual terminal, only WPS module installed
Seems like calling b.getCanonicalPath() at some point would solve the problem
I’m just not sure where
Ian
Jody Garnett
Ian Turton
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ian Turton
This is probably being caused by one of my fixes.
https://github.com/geoserver/geoserver/pull/7222
https://github.com/geoserver/geoserver/security/advisories/GHSA-9v5q-2gwq-q9hq
Steve Ikeoka
Sent: Thursday, December 7, 2023 7:23 AM
To: Jody Garnett <jody.garnett@…403…>
Cc: Geoserver-devel geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Platform independent binary is broken on main
On Thu, 7 Dec 2023 at 15: 07, Jody Garnett <jody. garnett@ gmail. com> wrote: I tested also, and determined that the only way to get that path was to start from the bin folder. However that is working for me, testing geoserver-main-latest-bin
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
Please use caution with links, attachments, and any requests for credentials.
ZjQcmQRYFpfptBannerEnd
Ian
Jody Garnett
    GEOSERVER DATA DIR is /home/aaime/devel/gs_releases/geoserver-2.24.1/bin/…/data_dir
cause-message : Contains invalid ‘…’ path: /home/aaime/devel/gs_releases/geoserver-2.24.1/bin/…/data_dir
line number : 17
version : 2.24.1
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:81)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:68)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:52)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:136)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1464)
Looking at the bin I have handy, 2.23.3 is still working fine, even with URL checks enabled (enabled them and restarted).
GeoServer 2.24.0 also loads fine from bin, with a relative data dir.
But 2.24.1 does not so… check the differences between 2.24.0 and 2.24.1
Ian
Ian Turton
Geoserver-devel mailing list
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Ian Turton
Jody,
I don’t think it’s URL checks, as indicated, it’s not happening on 2.23.x with URL checks enabled.
Grepping for the error message I’ve found this:
https://github.com/geoserver/geoserver/blob/b5994fa08938d8c8d3d894fdaf889da2d4a97eeb/src/platform/src/main/java/org/geoserver/platform/resource/Files.java#L65
Looks like a possible candidate, it’s a recent change as well, and while it’s on 2.23.x, it’s not found in 2.23.3 (landed after that release).
Jody Garnett
Ian Turton
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Sorry, not happening on 2.23.3
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Looks like it is a combo of how you run startup.sh (if it produces a relative path or not), and being more careful of the use of relative paths within data directory.
There is a PR https://github.com/geoserver/geoserver/pull/7317 to review.
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
This is addressed and maintenance release can go out this week as planned (assuming we have a volunteer to do so).
Jody Garnett
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
