[Geoserver-devel] Postgis estimated_extent completely off the mark?
some of you may know that in geotools we want to
add the ability to compute the bounds using estimated
extents to have a nice speedup, should the user decide
that the approximation of estimated extents is ok for him.
Hum, well, I tried this on my local db with the tiger roads network,
and the result are the followings:
tiger2005fe=# vacuum analyze major_roads;
VACUUM
tiger2005fe=# select estimated_extent('major_roads','gen_full');
                               estimated_extent
  BOX(-136.358154296875 17.6881694793701,-64.7429351806641 59.4498023986816)
(1 row)
tiger2005fe=# select extent(gen_full) from major_roads
tiger2005fe-# ;
                                    extent
  BOX(-170.837387084961 -14.3779020309448,144.914001464844 66.9222869873047)
Hem, this is not 5% error, it's totally off the mark.
What's going on? I'm on windows, postgres 8.1.5.
The difference is the same in other tables that do
use polygonal features.
Some more info about the tables:
tiger2005fe=# select postgis_version();
             postgis_version
  1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 row)
tiger2005fe=# \d major_roads;
                              Table "public.major_roads"
     Column | Type | Modifiers
  state | text |
  gen_full | geometry |
  gen_1 | geometry |
  gen_2 | geometry |
  gen_3 | geometry |
  interstate | integer |
  ushighway | integer |
  statehighway | integer |
  othername | text |
  fid | integer | not null default nextval('major_roads_fid_seq'::regcl
ass)
Indexes:
     "fid_pkey" PRIMARY KEY, btree (fid)
     "major_roads_spatial_ind" gist (gen_full)
     "major_roads_spatial_ind1" gist (gen_1)
     "major_roads_spatial_ind2" gist (gen_2)
     "major_roads_spatial_ind3" gist (gen_3)
tiger2005fe=# select * from geometry_columns;
  f_table_catalog | f_table_schema | f_table_name | f_geometry_column | coord
_dimension | srid | type
          2 | 1 | GEOMETRY
                  | public | major_roads | gen_full |
          2 | 1 | GEOMETRY
                  | public | major_roads | gen_1 |
          2 | 1 | GEOMETRY
                  | public | major_roads | gen_2 |
          2 | 1 | GEOMETRY
                  | public | major_roads | gen_3
Hum, may it be because the real geometry type is not declared?
Hi Andrea,
I am not sure here but I think for the function to be accurate within 5% the stats for the table have to be up to date. This can be done with a an ANALYZE on the table. Any change if you try analyzing the tale first?
Andrea Aime wrote:
VACUUM
                               estimated_extent
(1 row)
tiger2005fe-# ;
                                    extent
             postgis_version
(1 row)
  state | text |
  gen_1 | geometry |
  gen_2 | geometry |
  gen_3 | geometry |
  othername | text |
ass)
Indexes:
          2 | 1 | GEOMETRY
          2 | 1 | GEOMETRY
          2 | 1 | GEOMETRY
          2 | 1 | GEOMETRY
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-devel mailing list
!DSPAM:4007,45ffe306282334820651628!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
VACUUM
                               estimated_extent
(1 row)
tiger2005fe-# ;
                                    extent
Ah, if you're wondering about how this is possible, my guess is that
estimated_extent is for some reason not considering Hawaii (still USA, but very very far away)
Justin Deoliveira ha scritto:
Hi Andrea,
VACUUM
                               estimated_extent
Look at the first statement in the psql log :slight_smile:
Oh, I did run a full vacuum analyze too, without the table name.
Right, sampling.
Small enough that a random sample has a chance of missing them. Northern islands in Alaska, Hawaii, etc.
P
VACUUM
                               estimated_extent
(1 row)
tiger2005fe-# ;
                                    extent
postgis-users mailing list
postgis-users@anonymised.com
http://postgis.refractions.net/mailman/listinfo/postgis-users
Paul Ramsey ha scritto:
Right, sampling.
So this is a feature, not a bug, apparently.
Heh, then the docs should say that estimated_extent is 5% off the
proper bounds if features are uniformly distributed in the actual
bounds :slight_smile:
If you have data with strange distribution patters (such as USA
states) better not rely on it.
> Right, sampling.
Yes, it's due to the way in which the sampling works. Note that you can
increase the number of sampled rows using ALTER TABLE x ALTER COLUMN y
SET STATISTICS z and then re-ANALYZING (the default value is 10, so
perhaps a value of 100 would provide better results). I'm not sure where
the figure of 5% from proper bounds comes from though - I would have
imagined it depends on the sample size relative to the population size,
but then I haven't studied statistics properly for several years now :frowning:
Kind regards,
Mark.
Right, sampling.
Counter-intuitively it is more tightly linked to the absolute size of the sample. A 1000 person sample of a population of 10000 does not have a markedly higher performance than a 1000 person sample of a population of 1000000.
P
Nice tip. I tried it out:
alter table major_roads alter column gen_full set statistics 1000;
                               estimated_extent
  BOX(-136.358154296875 17.6865196228027,-64.5742340087891 59.6282997131348)
Sigh... the result is the same as before...
I tried setting a value bigger than 1000, the result is:
tiger2005fe=# alter table major_roads alter column gen_full set statistics 10000;
WARNING: lowering statistics target to 1000
ALTER TABLE
It seems there is no way to make it close to being correct...
If any developer is curious and wants the data, I do have a compressed postgres dump of this table, it's around 125MB.
