we might have a blocker for the release, the GeoServer part at least: the CSW extension is not
going to work under Tomcat due to an unfortunate startup sequence.
I’ve explained a bit what’s happening in https://github.com/geoserver/geoserver/pull/1921
and provided one possible approach to breaking the circular dependency (which is not static,
but due to GeoServerLoader bean post processing).
Should we apply that (or another) fix before releasing 2.10.0?
While CSW is a surefire way to cause the issue, other extensions or different classloading orders
could cause the startup to fail even with just core modules (anything that causes EntityResolverProvider
to be instantiated before GeoServer will cause the problem).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
