[Geoserver-devel] problem implementing OWS service
I’m following instructions on
http://docs.geoserver.org/stable/en/developer/programming-guide/ows-services/implementing.html
to learn how to implement custom OWS service…
I pretty much followed all the initial instructions and copied hello-1.0.jar in C:\geoserver-2.0.2\webapps\geoserver\WEB-INF\lib and restarted geoserver
when I go to http://localhost:8080/geoserver/ows?request=sayHello&service=hello&version=1.0.0
I get
<ows:ExceptionReport version=“1.0.0” xsi:schemaLocation=“http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd”>
<ows:Exception exceptionCode=“InvalidParameterValue” locator=“service”>
ows:ExceptionTextNo service: ( hello )</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
geoserver logs below.
any ideas why this would be?
thank you
71495 [btpool0-2] INFO org.apache.wicket.protocol.http.WebApplication - [GeoServerApplication] Started Wicket version 1.3.7 in deployment mode
16 Aug 13:44:24 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: No service: ( hello )
at org.geoserver.ows.Dispatcher.findService(Dispatcher.java:776)
at org.geoserver.ows.Dispatcher.service(Dispatcher.java:381)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:214)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
Signed,
Alessandro Ferrucci
By the way I am using Geoserver 2.0.2.
thank you
On Mon, Aug 16, 2010 at 1:50 PM, Alessandro Ferrucci <alessandroferrucci@anonymised.com> wrote:
I get
</ows:Exception>
thank you
Signed,
Alessandro Ferrucci
Signed,
Alessandro Ferrucci
Hi Alessandro,
The error message means that your plugin is not being picked up. Two things could cause this:
  1. the jar is not physically there
  2. the jar is there but does not include the applicationContext.xml file
Since you have ruled out 1) i would assume it is 2. To check unjar the hello.jar file you are copying over (any zip program should be able to do this) and check if the applicationContext.xml is included in its contents.
-Justin
On Mon, Aug 16, 2010 at 11:50 AM, Alessandro Ferrucci <alessandroferrucci@anonymised.com> wrote:
I get
</ows:Exception>
thank you
Signed,
Alessandro Ferrucci
This SF.net email is sponsored by
Make an app they can’t live without
Enter the BlackBerry Developer Challenge
http://p.sf.net/sfu/RIM-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
