Having some problems running the 1.4.x branch. Attached is the maven
output when doing "maven run" in the jetty module.
Jonas
(attachments)
maven_jetty_log.txt (8.22 KB)
Jonas
Hi Jonas,
This was a problem with the ordering of elements in the web.xml. I have commited the fix, if you update the main module you should have some better luck.
-Justin
Jonas Johansson wrote:
output when doing "maven run" in the jetty module.Jonas
~/geoserver_src/1.4.x/org.vfny.geoserver.jetty$ maven run
__ __
| \/ |__ _Apache__ ___
| |\/| / _` \ V / -_) ' \ ~ intelligent projects ~
|_| |_\__,_|\_/\___|_||_| v. 1.0.2build:start:
run:
[java] 21:46:30.833 EVENT Starting Jetty/4.2.9
[java] 21:46:31.049 WARN!! ERROR@anonymised.com:/home/jonas/geoserver_src/1.4.x/target/geoserver/WEB-INF/web.xml line:288 col:11 : org.xml.sax.SAXParseException: The content of element type "web-app" must match "(icon?,d isplay-name?,description?,distributable?,context-param*,filter*,filter-mapping*,listener*,servlet*,servlet- mapping*,session-config?,mime-mapping*,welcome-file-list?,error-page*,taglib*,resource-env-ref*,resource-re f*,security-constraint*,login-config?,security-role*,env-entry*,ejb-ref*,ejb-local-ref*)".
[java] 21:46:31.051 WARN!! Configuration error on /home/jonas/geoserver_src/1.4.x/org.vfny.geoserver.je tty/../target/geoserver
[java] org.xml.sax.SAXParseException: The content of element type "web-app" must match "(icon?,display- name?,description?,distributable?,context-param*,filter*,filter-mapping*,listener*,servlet*,servlet-mapping *,session-config?,mime-mapping*,welcome-file-list?,error-page*,taglib*,resource-env-ref*,resource-ref*,secu rity-constraint*,login-config?,security-role*,env-entry*,ejb-ref*,ejb-local-ref*)".
[java] at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Erro rHandlerWrapper.java:236)
[java] at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.error(ErrorHandlerWrapper.ja va:172)
[java] at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.ja va:382)
[java] at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.ja va:316)
[java] at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.handleEndElement(XMLDTDValid ator.java:2048)
[java] at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.endElement(XMLDTDValidator.j ava:932)
[java] at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(XM LDocumentFragmentScannerImpl.java:1241)
[java] at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDi spatcher.dispatch(XMLDocumentFragmentScannerImpl.java:1685)
[java] at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLD ocumentFragmentScannerImpl.java:368)
[java] at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.j ava:834)
[java] at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.j ava:764)
[java] at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:148)
[java] at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.jav a:1242)
[java] at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
[java] at org.mortbay.xml.XmlParser.parse(XmlParser.java:125)
[java] at org.mortbay.xml.XmlParser.parse(XmlParser.java:140)
[java] at org.mortbay.jetty.servlet.WebApplicationContext.start(WebApplicationContext.java:387)
[java] at org.mortbay.http.HttpServer.start(HttpServer.java:647)
[java] at org.mortbay.jetty.Server.main(Server.java:429)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[java] at java.lang.reflect.Method.invoke(Method.java:585)
[java] at org.mortbay.start.Main.invokeMain(Main.java:152)
[java] at org.mortbay.start.Main.start(Main.java:482)
[java] at org.mortbay.start.Main.main(Main.java:90)
[java]
[java] 21:46:31.063 EVENT Started SocketListener on 0.0.0.0:8080
[java] 21:46:31.063 WARN!!
[java] org.mortbay.util.MultiException[org.xml.sax.SAXParseException: The content of element type "web- app" must match "(icon?,display-name?,description?,distributable?,context-param*,filter*,filter-mapping*,li stener*,servlet*,servlet-mapping*,session-config?,mime-mapping*,welcome-file-list?,error-page*,taglib*,reso urce-env-ref*,resource-ref*,security-constraint*,login-config?,security-role*,env-entry*,ejb-ref*,ejb-local -ref*)".]
[java] at org.mortbay.http.HttpServer.start(HttpServer.java:624)
[java] [0]=org.xml.sax.SAXParseException: The content of element type "web-app" must match "(icon?,disp lay-name?,description?,distributable?,context-param*,filter*,filter-mapping*,listener*,servlet*,servlet-map ping*,session-config?,mime-mapping*,welcome-file-list?,error-page*,taglib*,resource-env-ref*,resource-ref*, security-constraint*,login-config?,security-role*,env-entry*,ejb-ref*,ejb-local-ref*)".
[java]
[java] 21:46:53.020 EVENT Started HttpContext[/]The browser result for http://localhost:8080/geoserver is
HTTP ERROR: 404 /geoserver Not Found
RequestURI=/geoserver
