[Geoserver-devel] Promoting nightly build, as a stand-in for release candidate testing
In the last meeting we decided not to make a release-candidate, in part due to assembly instructions having a test automation (to ensure they still run). We will be exposed to a bit more risk actually trying the downloads in different environments of course …
May I recommend we ask our user forum to help test nightly builds ahead of 2.26.0 release…
Checking 2.26.0 release notes for new features and testable items:
  • Java 17 newly supported
  • MapML new features Representation Style Classes and include query filters, custom dimensions, … lots here.
  • Raster Attribute Table - new extension
  • Multi-layer output in CSS ← this could be a new feature
  • GeoPackage QGIS compatibility
Please reply with anything more specific to test
It may also be a good time to review community modules / extensions:
  • graticule → extension or main
  • geofence is using a snapshot
Jody Garnett
Not really, it has been a new extension since 2.25.1
Yes, along with scale dependencies by the Z level.
Also, see the new VT encoding options.
Does it have a maintainer? Otherwise neither extension nor main.
As far as I know, it has been only one production usage so far*, seems green for supported status.
*: go to https://view.eumetsat.int/productviewer?v=default, open “overlays”, enable “graticule (dark)” or light.
On Wed, Sep 4, 2024 at 5:29 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Additionally, it’d be great if we could get this two pull requests in:
Upgrade Azure Blobstore from legacy azure-sdk (11.0) to latest (12.27.1)
Upgrade cog-rangereader-azure to azure-sdk:12.27.1
They make sure the imageio-ext S3 and Azure cog range readers, and the GWC Azure blobstore can co-exist by upgrading to the current version of the azure sdk and a common netty dependency version.
This other one would make for a good new feature:
[GEOS-11421] Match webui workspace admin functionality in the REST API
I’ll try to get it ready by tomorrow Friday. As far as I can tell it’s all working good and our customer is heavily testing it, what’s missing is mostly updating the documentation and a good commit message. But it’s not mandatory and if there’s no time for a good review we can leave it out.
Jody Garnett
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Gabriel Roldán
Geospatial Developer
Oh, the imageio-ext one would require cutting a release so I'm also not
sure if Andrea or someone else at GeoSolutions will have time for it?
On Thu, Sep 12, 2024 at 12:41 PM Gabriel Roldan <
gabriel.roldan@anonymised.com> wrote:
Additionally, it'd be great if we could get this two pull requests in:
<https://github.com/GeoWebCache/geowebcache/pull/1316&gt;
<https://github.com/geosolutions-it/imageio-ext/pull/312&gt;
<https://github.com/geoserver/geoserver/pull/7803&gt;
I'll try to get it ready by tomorrow Friday. As far as I can tell it's all
working good and our customer is heavily testing it, what's missing is
mostly updating the documentation and a good commit message. But it's not
mandatory and if there's no time for a good review we can leave it out.
On Wed, Sep 4, 2024 at 12:29 PM Jody Garnett <jody.garnett@anonymised.com...>
in different environments of course ..
of 2.26.0 release...
   - Java 17 newly supported
   - MapML new features Representation Style Classes and include query
   filters, custom dimensions, ... lots here.
   - Raster Attribute Table - new extension
   - Multi-layer output in CSS <- this could be a new feature
   - GeoPackage QGIS compatibility
   - graticule --> extension or main
   - geofence is using a snapshot
Jody Garnett
Geoserver-devel mailing list
*camptocamp*
*Gabriel Roldán*
For jai-ext:
Not critical at all, if a release of jai-ext is anticipated please include.
Jody Garnett
Oh, the imageio-ext one would require cutting a release so I’m also not sure if Andrea or someone else at GeoSolutions will have time for it?
Jody Garnett
camptocamp
Gabriel Roldán
Hi Gabriel,
I’ve merged the PRs and performed a release of imageio-ext 1.14.13.
I’ll leave it up to you to upgrade the version numbers in GT/GWC/GS (all projects have one).
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Jody Garnett
camptocamp
Gabriel Roldán
Hi Jody,
there is no jai-ext release planned, like… ever. They are done ad-hoc when Geosolutions needs one.
I’ve just merged the PRs and released a 1.1.27 for you, you’ll need to take over and update the version
numbers in the root level poms of the various projects (all of them, GT/GWC/GS… now here is where
a bit of BOM usage across projects would help…)
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Jody Garnett
camptocamp
Gabriel Roldán
Okay! I do not think it is so critical. Let me check in with Peter to see about updating the dependencies.
And yes let’s put a proposal together for bill of materials POM improvements.
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Jody Garnett
camptocamp
Gabriel Roldán
