I need an easy to set up FTP server for GeoServer
so that remote admins can upload data.
Alessio some time ago pointed me at Apache Mina FtpServer,
and this tutorial shows how to create an embedded FTP
server the easy way:
http://mina.apache.org/ftpserver/embedding-ftpserver-in-5-minutes.html
GeoSolutions actually added that into GeoBatch already.
Alessio, Simone, is it working fine for you?
I guess this would be a contribution of general interest.
Yes, setting up a stand alone FTP server for the same purpose
is not hard, but requires deciding which one you want to use
platform per platform, configuring it, creating the necessary
users (a separate set from GeoServer own users), and making
sure the files created by the server can be read
(and eventually written) by GeoServer.
The idea of the embedded module is that you drop it in and
it just start serving the data directory contents to all
the GS users that have administration powers (since you need
to be able to configure the data afterwards anyways).
Basically a no options easy install that gets you going
in 5 minutes.
Given it's a full fledged FTP server we also get much better
service than just file upload in forms, for example, no
limit on file sizes, restartable services, easy multiple uploads,
and a ton of existing clients on various platforms that
can access it directly.
So, opinions?
Andrea Aime
OpenGeo - http://opengeo.org
