GeoTools / GeoServer PMC meeting - 2020-10-13### Attending
Jukka Rahkonen
Andrea Aime
Jody Garnett
Kevin Smith
Actions from last meeting:- Jody: Switch GeoTools bin to use assembly, grab everything, folks who want custom units can use exclude (still todo?)
Andrea: remove bin release if assembly does not work (out backup plan)
Jody: Contact SAC to follow up with Tom on domain name transfer (any update? None waiting on Tom)
Agenda1. Build server update
GeoServer October release?
Unchecked branch update
GWC parameter filters
Chit chat
Actions- Jody to check the the GeoTools bin assembly
- Andrea marching on in the unchecked branch
Build server update
Everything is building fine besides GeoFence, Nexus fixed.
Jody to turn on all the parallel builds again (gently!).
Skipping releases in October to go back on having a release per month, last month we released both stable and maintenance.
Spreadsheet here: https://docs.google.com/spreadsheets/d/1voHK_V8ZdbN-yqqUkqrl0rJsLjqiOjmVwJkm1Fjd0z4/edit#gid=0
Started with 3000 warnings, down to 1000, should go down quickly to zero from here.
Using IntelliJ to quickly locate the issues module by module.
Landed on master to make parameter filters update more robust. Running in production for a couple of weeks, we are backporting stuff.
DGGS progress
Clickhouse storage: https://github.com/geoserver/geoserver/pull/4535
Chit chat
OSGeo nominations, October 24 : https://wiki.osgeo.org/wiki/Election_2020
Any committers to nominate? https://www.osgeo.org/about/charter-members/
Foss4g-KO
- anyone want to submit? Jody? Ian?
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
