I am looking at some editing issue with QGIS and found out that the HTTP client
in QGIS seems to be caching all GetCapabilities and DescribeFeature type responses
because GeoServer does not add any caching header.
So for example, if a layer is added or its structure is changed, the edits will fail, or adding
the layer becomes impossible (first the layer is listed in the “add layer” dialog, then
qgis claims the document is not in the capabilities document… that’s a bit hilarious).
Anyone minds if we add by default “Cache-Control: no-cache” to the capabilites and
describe feature type responses?
Clients would be supposed to use the sequence number checks, but apparently qgis
does not, and indeed he caching behavior of a http client is not clearly defined
when there are no caching headers in the responses.
I believe most desktop clients and browsers play it safe and request again, but it does
not hurt to be explicit, no?
For Capabilities one could even add a “Cache-Control: revalidate” along with an eTag
that happens to be the same as the update sequence number, to allow for conditional
requests (If-None-Match) support.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
