I was checking a random failure in gs-metadata module, that is breaking the builds on Github and the build server (there are others, this one is popping up frequently though).
The logs are ridden with 300+ instances of errors similar to this one:
Nov 27, 2023 6:22:16 PM org.geoserver.metadata.data.service.impl.ConfigurationServiceImpl readConfiguration
SEVERE: Cannot construct instance of org.geoserver.metadata.data.dto.impl.MetadataConfigurationImpl (although at least one Creator exists): no String-argument constructor/factory method to deserialize from String value (‘klopt-niets-van’)
at [Source: (org.geoserver.platform.resource.FileSystemResourceStore$FileSystemResource$1); line: 1, column: 1]
com.fasterxml.jackson.databind.exc.MismatchedInputException: Cannot construct instance of org.geoserver.metadata.data.dto.impl.MetadataConfigurationImpl (although at least one Creator exists): no String-argument constructor/factory method to deserialize from String value (‘klopt-niets-van’)
at com.fasterxml.jackson.databind.exc.MismatchedInputException.from(MismatchedInputException.java:63)
at com.fasterxml.jackson.databind.DeserializationContext.reportInputMismatch(DeserializationContext.java:1739)
at com.fasterxml.jackson.databind.DeserializationContext.handleMissingInstantiator(DeserializationContext.java:1364)
at com.fasterxml.jackson.databind.deser.std.StdDeserializer._deserializeFromString(StdDeserializer.java:311)
at com.fasterxml.jackson.databind.deser.BeanDeserializerBase.deserializeFromString(BeanDeserializerBase.java:1504)
at com.fasterxml.jackson.databind.deser.BeanDeserializer._deserializeOther(BeanDeserializer.java:197)
at com.fasterxml.jackson.databind.deser.BeanDeserializer.deserialize(BeanDeserializer.java:187)
at com.fasterxml.jackson.databind.deser.DefaultDeserializationContext.readRootValue(DefaultDeserializationContext.java:323)
at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:4825)
at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3809)
at org.geoserver.metadata.data.service.impl.ConfigurationServiceImpl.readConfiguration(ConfigurationServiceImpl.java:195)
A few things:
- The exception is per se legit, one cannot load a MetadataConfigurationImpl from a YAML file that contains only the string ‘klopt-niets-van’)
- The code is just logging the error… but making a lot of noise about it, especially at the current SEVERE logging level. More so considering that the code is blindly looping over files in a directory and trying to deserialize 3 different types of clases in turn, try the next if one fails. This needs to be fixed, we cannot have tests logging so loudly for nothing (nor we should have runtime code doing so).
- For all the noise it’s making, it’s not the actual cause of the failure.
Niels could you please remove this wall of text from our build execution?
Now, going to the actual failure, it’s just one:
[ERROR] Tests run: 6, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 4.447 s <<< FAILURE! - in org.geoserver.metadata.web.TemplatePageTest
[ERROR] testPageNewSave(org.geoserver.metadata.web.TemplatePageTest) Time elapsed: 0.043 s <<< ERROR!
java.lang.NullPointerException
at org.geoserver.metadata.web.TemplatePageTest.before(TemplatePageTest.java:37)
At line 37 the only NPE I see [happening](http://not so random?), is having the tester field being null.
That should not be happening, because JUnit ensures that the @anonymised.com methods of a parent class are run before the ones of the children, and we have this.
However… the tests are not using vanilla JUnit, but Spring own test runner, which runs the tests in a different way. Maybe that’s why it’s happening?
Thad said, the occurrence of the failure has become so common that we should probably just disable these tests, until they can get fixed. Or maybe, better, rewrite them to use GeoServer integration test support, which is generally better known in this community?
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
