[Geoserver-devel] [Re: [Geotools-devel] Upcomming Release]
-----Forwarded Message-----
To: dblasby@anonymised.com
Cc: geotools-devel@lists.sourceforge.net
Subject: Re: [Geotools-devel] Upcomming Release
Date: Tue, 15 Mar 2005 14:32:51 -0800
On Tue, 2005-03-15 at 14:20, dblasby@anonymised.com wrote:
> I'm not sure what was up with my build yesterday but I checkout a new
> version of Geotools and almost everything worked again. (I use the
> gt2-main.jar from my geotools maven build)
> SVN was having a few issues yesterday, but I dont think that was it.
> There are some new issues;
> 1. The FeatureType namespace was changed to a URI instead of a String.
> I committed changes so you could compile, but I'm not 100% sure if that
> was the best thing to do. Dave Zweirs said that what I did should be
> okay.
Think point 1 was for Geoserver? I have GT compiling and passing most
tests ...
> 2. The FeatureType constraint stuff isnt currently working.
> Unfortunately, datastores like Shapefile put length constraints on
> their data (for the .dbf file) so they're currently not working. I
> talked to Dave Zweirs and pointed out where and why its throwing
> errors.
Thanks Dave, applied them.
> 3. The test suits have a bunch of lines like this:
> tempExp2 = factory.createAttributeExpression(null);
> This is causing ambiguity problems because there is a
> #createAttributeExpression(FeatureType) and
> #createAttributeExpression(AttributeType);
Update (part of this mornings fixes).
> 4. Others are reporting problems with the new CRS stuff in GeoTools -
> I'm currently using a version from a few days ago. The new stuff is
> (apparently) better at handling ellipsoid transformations so I really
> want to the use the new one.
> 5. There are some rendering issues - I'll probably jira them and not
> worry about them until the 1.3.0 release.
> So, it looks like there might be a little delay in getting a release
> out. As soon as the above are fixed (and I dont find any more serious
> issues), I'll tag a release.
> dave
Thanks Dave,
David
> This mail sent through IMP: https://webmail.limegroup.com/
> SF email is sponsored by - The IT Product Guide
> Read honest & candid reviews on hundreds of IT Products from real users.
> Discover which products truly live up to the hype. Start reading now.
> http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click
> Geotools-devel mailing list
> Geotools-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geotools-devel
