I'm going home now. Once there, will talk to Justin to review the object model
I'm using to represent the join support in sde (actually works for any sql
select expression). Also have unit tests to commit, and will be working on
setting up the tests used for bgs with fake data, that demostrates outputing
of GeoSciML schema.
On Tuesday 07 March 2006 07:01, Jody Garnett (JIRA) wrote:
[ http://jira.codehaus.org/browse/GEOS-558?page=all ]
Jody Garnett reassigned GEOS-558:
---------------------------------Assign To: Justin Deoliveira (was: Gabriel Roldán)
Talking to Rob appraently TOPP has this work
> Community Schema Config API (ArcSDE limited)
> Key: GEOS-558
> URL: http://jira.codehaus.org/browse/GEOS-558
> Project: GeoServer
> Type: Sub-task
> Reporter: Jody Garnett
> Assignee: Justin Deoliveira
> Original Estimate: 3 days
> Remaining: 3 days
> Justin you are getting the nod to define the API (you have practice
> ), if you can work with gabriel to define a minimal api that is caters to
> what ArcSDE can do. ArcSDE uses its own query system, and will be more
> limited then SQL. Gabriel if you get to this need first, just go ahead
> and ask Justin for review. Justin will you be using the DTO to seperate
> out geoserver from the config app (and from the format on disk?). Or will
> the ui modify the datastore used by the running GeoServer?
> The initial estimate is 3d - because this is only a java interface.
Gabriel Roldán (groldan@anonymised.com)
Axios Engineering (http://www.axios.es)
Tel. +34 944 41 63 84
Fax. +34 944 41 64 90
