[Geoserver-devel] Recommended tool to edit GeoServer code
Hello all
what is the recommended tool (IDE) to edit GeoServer java code??
Dr. Eng. Ashraf Tammam
Eclipse:
http://docs.geoserver.org/latest/en/developer/quickstart/index.html
http://docs.geoserver.org/latest/en/developer/eclipse-guide/index.html
On 29/05/13 14:49, Ashraf Tammam wrote:
Hello all
Introducing AppDynamics Lite, a free troubleshooting tool for Java/.NET
Get 100% visibility into your production application - at no cost.
Code-level diagnostics for performance bottlenecks with <2% overhead
Download for free and get started troubleshooting in minutes.
http://p.sf.net/sfu/appdyn_d2d_ap1
Geoserver-devel mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
As Ben already said, all core developers (to my knowledge) use Eclipse to edit the code,
however I believe other people managed to get it loaded in Netbeans as well, we just
lack instructions on how to
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Please keep discussions on-list.
I use and recommend the Java EE bundle. It includes support for remote deployment and debugging and a validating XML editor.
Note also that the Oracle Java 6 JDK is the current supported platform for development and deployment.
I am currently using eclipse-jee-juno-SR2-linux-gtk-x86_64 with jdk1.6.0_45.x64.
Kind regards,
Ben.
On 29/05/13 15:13, Ashraf Tammam wrote:
which one of these??
http://www.eclipse.org/downloads/
*From:* Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
*To:* Ashraf Tammam <aft1972@anonymised.com>
*Cc:* "geoserver-devel@lists.sourceforge.net"
<geoserver-devel@lists.sourceforge.net>
*Sent:* Wednesday, May 29, 2013 9:03 AM
*Subject:* Re: [Geoserver-devel] Recommended tool to edit GeoServer code
Eclipse:
> Hello all
> Regards,
<mailto:Geoserver-devel@lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
<mailto:Ben.Caradoc-Davies@anonymised.com>>
Software Engineer
Software Engineer
edit the code,
well, we just
Nothing special is necessary for NetBeans, just hit open project and select one of the GeoServer directories containing a pom. The IDE picks it up nicely. If the project has not been built yet, it AFAIK asks you to build the project so that it can inspect the classes (just confirming the dialog should be sufficient in that case). I have always built the project directly using a command-line maven though, as a matter of personal preference.
Martin Sucha
