this morning I’ve found that most of our Jenkins jobs were failing to connect to git, since sometimes yesterday, with this error:
Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --force --progress -- git://[github.com/geotools/geotools.git](http://github.com/geotools/geotools.git) +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: fatal: remote error:
The unauthenticated git protocol on port 9418 is no longer supported.
Please see [https://github.blog/2021-09-01-improving-git-protocol-security-github/](https://github.blog/2021-09-01-improving-git-protocol-security-github/) for more information.
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2671)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2096)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:84)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:618)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:999)
... 11 more
The error points at a blog explaining the issue. Long story short, most jobs were configured like this, with the wrong URL and no authentication:
Thankfully, fixing the config is not hard:
Notice the column in the URL, where a slash used to stand, and provide credentials to be used for access (both are needed).
The very annoying bit was that… it needed to be done for all jobs!
I went through all GeoTools, GeoWebCache, GeoServer, GeoFence, release jobs and hopefully fixed them.
I hope I did not copy/paste the wrong URL in some projects, but it’s a possibility …, e.g., pasting the GeoTools URL in a GeoServer job… a second pair of eyes would certainly help.
What I left out:
- CITE jobs, as I’ve found other issues (pointing to the wrong repo) that need to be fixed, escalated this internally in GeoSolutions
- GeoScript jobs, as they point directly to Jericks account, and that seems wrong (it should be pointing to geoscript no?). There seems to be a redirect from one to the other, but I decided not to mess with it, as I’m not sure what is going on.
- Other jobs not included in the categories above (however the 2.18.x train of builds got updated).
The build server has now a very long job queue… guess they all trigger on reconfiguration. Hopefully the server is going to be back to normal within the day…
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
