[Geoserver-devel] redirecting system.out and system.err
One thing that always causes questions is our standard JAI stack trace.
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
at java.security.AccessController.doPrivileged(Native Method)
etc…
I wonder if this article https://blogs.oracle.com/nickstephen/entry/java_redirecting_system_out_and could help us capture this output (and filter it out?).
Jody Garnett
Looks like another approach would be to register a JAI listener:
see line 280 in https://java.net/projects/jai-core/sources/svn/content/trunk/src/share/classes/com/sun/media/jai/mlib/MediaLibAccessor.java?rev=111
On Wed, Apr 16, 2014 at 9:12 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
etc…
Jody Garnett
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/NeoTech
Geoserver-devel mailing list
Ian Schneider
Software Engineer | Boundless
ischneider@anonymised.com
On Wed, Apr 16, 2014 at 5:12 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
pure Java mode.
        etc...
https://blogs.oracle.com/nickstephen/entry/java_redirecting_system_out_andcould help us capture this output (and filter it out?).
Seems like an interesting avenue. For the JAI one I'd follow Ian
suggestion, but of course that one won't tap
other sysout that might have been left in the code by mistake.
So I'd also be good with the one you propose, with a few observations.
Geoserver can be deployed
along other applications, overriding the out is probably going to affect
everybody,
and it might be "nasty" to have other apps outs and errs in our logs only.
Also, the method you are going to use can throw a SecurityException (
http://docs.oracle.com/javase/6/docs/api/java/lang/System.html#setOut(java.io.PrintStream)
and I bet in some enviroments it will.
Long story short:
* it must be possible to de-activate the system out/err redirect to logs
* we should guard the attempt to redirect them in a try/catch to avoid
geoserver startup issues in locked down environments
Also, not sure what is going to happen if we re-init the logging system at
runtime
when someone changes the logging levels from the GUI, that is, are we going
to lose
the loggers used to redirect out and err, or are they maybe ignoring the
new logging
settings, and so on (maybe not, but we should check).
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I am pleased with Ian’s suggestion, as the JAI stack traces that cannot be avoided is what I am trying to cut down on.
Messing with standard out sounds very risky.
​Jody
Just to confirm I have tried out adding a listener, in GeoTools init() and it helpfully cleans up the log.
Jody Garnett
On Thu, Apr 17, 2014 at 2:21 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
On Mon, May 12, 2014 at 8:57 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
Good, let's do that then. Wondering... is GeoServer calling GeoTools init
method anywhere?
I guess the place would be GeoServerInitStartupListener
Ing. Andrea Aime
@geowolf
Technical Lead
Actually I just checked and it is not, although I have not checked if Spring calls it. I assume it should be called where all the other init logic is.
Jody Garnett
On Mon, May 12, 2014 at 12:52 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, May 12, 2014 at 8:57 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Good, let’s do that then. Wondering… is GeoServer calling GeoTools init method anywhere?
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, May 12, 2014 at 9:59 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
logic is.
Yes, most of the initialization that we have to do before the "show" starts
is done inside GeoServerInitStartupListener,
it is called before the spring context initialization happens
Ing. Andrea Aime
@geowolf
Technical Lead
Just finished a full GeoTools build with the change applied, will issue a pull request now.
Jody Garnett
On Mon, May 12, 2014 at 1:01 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, May 12, 2014 at 9:59 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Yes, most of the initialization that we have to do before the “show” starts is done inside GeoServerInitStartupListener,
Ing. Andrea Aime
@geowolf
Technical Lead
Actually can you think of a way to get GeoTools init called in our test cases? It would really cut down on the logs when I run locally.
Jody Garnett
On Mon, May 12, 2014 at 1:02 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Mon, May 12, 2014 at 9:59 PM, Jody Garnett <jody.garnett@anonymised.com.> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, May 12, 2014 at 10:02 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
You mean in the Geotools tests? Nope, they are all spread out, no structure.
In the GeoServer ones instead? Most of them are based on the same base
class, just put it there
Ing. Andrea Aime
@geowolf
Technical Lead
