following up a question about Java compatibility on the user list I’ve noticed
that the release jobs are hard-coded to use Java 11… which, if un-noticed,
would have made us release GeoServer 2.22.x and 2.21.x that might have been
Java 11 compatible only.
Hum… is it possible to make the builds parametric on the JDK too?
Or, maybe I’m worrying for nothing, as the target JVM compliance in the pom files
is Java 8 anyways (and we haven’t introduced usage of Java 11 API, as the
regular builds are happily on the green anyways)?
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
