I’m planning on building and releasing GeoTools 22.5, GeoWebCache 1.16.5 and GeoServer 2.16.5, with Kevin’s assistance on the GWC release
using:
- GeoTools commit 381779d0a2a0789391e47660e3291c4fb1bc2cad,
- GeoWebCache commit 5963f03d94908e340d0c381bc1f3c8757049ced4,
- GeoServer commit 4a23f54c8d1e1151eda7933c1f3e24d827d52ef1
I’ll let the relevant lists know when there are artifacts to test
Ian
Ian Turton
Hi Ian,
checking the revisions, it looks like that GWC 1.16.5 would be identical to 1.16.4,
I see no new changes in between… on the other end, GWC carries GT and JAI dependencies,
they should be covered in the dependency management of GeoServer, but I’m not 100% sure.
Well… I guess the one change could be “updated GeoTools to 22.5”, LOL
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
