== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I thought I checked the calendar correctly, I very easily could of made a mistake.
Remember we are gradually moving back on track after being delayed by a couple months due to the spring upgrade / java 8 thing. I thought our ideal was to release in August / Feb to take advantage of foss4g …
We recovered that already
It’s something that can be discussed, but requires a proposal… (once upon a time FOSS4G was in September, I remember
Justin pressing a “release” button directly during “state of geoserver”).
Result of meeting: 2.17.0 pushed back until march, an additional 2.15 maintenance release will be made by GeoSolutions (thanks!).
Because of summer vacations there does not seem to be capacity to release in August in alignment with FOSS4G.
It's something that can be discussed, but requires a proposal... (once upon
Justin pressing a "release" button directly during "state of geoserver").
