[Geoserver-devel] Restored xslt to release profile
Andrea,
when you promoted the inspire module to extension, it looks like you inadvertently removed the xslt module from the release profile, on both master and 2.3.x. I took the liberty of restoring xslt to the release profile on master and 2.3.x; please let me know if I have misunderstood! It has release descriptors so release fails if it is not built. Do you intend for xslt to be in 2.3.2? Let me know if my guess is wrong.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
On Thu, May 16, 2013 at 4:55 AM, Ben Caradoc-Davies <
Ben.Caradoc-Davies@anonymised.com> wrote:
Andrea,
Yes, I definitely intended to.
However the nightly builds does build xslt and has been doing so
successfully for a while,
and the artifacts get published, e.g.:
http://gridlock.opengeo.org/geoserver/2.3.x/ext-2013-05-15/
Makes me wonder if you are really building from a recent revision?
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
No, the nightlies just *looked* like they were working. But they were not. I think that, until I added it to the release profile, nightlies were just getting an old xslt jar from the repo, built as a side-effect of geoserver-2.3.x building with -PallExtensions and thus building xslt. geoserver-2.3.x-nightly builds with -Prelease,communityRelease and so did not include xslt until I fixed the pom.
http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/107/consoleFull
The list of modules being built ends with (no mention of XSLT):
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer Release Module
While building the release module, we also see:
[INFO] snapshot org.geotools:gt-vpf:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:xslt:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:xslt:2.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:restconfig:2.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:restconfig:2.3-SNAPSHOT: checking for updates from osgeo
After my pom fix:
http://hudson.opengeo.org/hudson/job/geoserver-2.3.x-nightly/108/consoleText
The list of modules being built ends with (XSLT present):
[INFO] XLST based WFS output format
And no xslt check in the release module. Looks fixed to me.
Kind regards,
Software Engineer
On Fri, May 17, 2013 at 4:15 AM, Ben Caradoc-Davies <
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@**csiro.au<Ben.Caradoc-Davies@anonymised.com>>>
http://gridlock.opengeo.org/**geoserver/2.3.x/ext-2013-05-**15/&lt;http://gridlock.opengeo.org/geoserver/2.3.x/ext-2013-05-15/&gt;
Ah, I see. Thanks for fixing it :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
