[Geoserver-devel] Rethinking the role of the web-app module
I'd like to propose a little modifications to the web-app module
that should help when building a customized version of GeoServer.
The current web-app module, as I see it, has the following issues:
- for some reason during the deploy of releases the jar ends up
  containing other jars. E.g. see
  http://repo.opengeo.org/org/geoserver/web/web-app/2.1.2/web-app-2.1.2.jar
  This is actually the .war file with a different name.
  This makes it hard to make a custom build on top of a release, which is
  annoying since most people interested in custom build do want to
  base it on a release.
- the web-app contains some crucial classes (filters), so it's needed,
  but at the same time make choices about the dependencies that
  might be unsuitable for custom builds. E.g., in some custom build
  we might decide that we only need wms and wfs, and only support
  for vector data, plus some assorted extras
  I know, one could use maven exclusion mechanism, but it's imho
  cleaner to add what is needed instead of listing what to remove
  (might be a matter of preference)
What I would like is not having to depend on web-app to start with.
A custom build often has to roll its own web.xml anyways, so I believe
the best way forward would just to move the classes implementing
the filters back in main and have web-app be just the wiring that
builds a .war, and nothing else.
Given that all the pieces in GeoServer are made to build a web app
moving back the filters in main should not cause any trouble (besides
being trivial).
Opinions?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
A big +1.
On a related note, one thing I found difficult when in need to build
an alternate web app for GeoNode was that secureCatalog, as defined in
main's applicationContext.xml, depends on accessRulesDao, defined in
applicationSecurityContext.xml, so it was not easy to depend on an
alternate security configuration.
I don't know much about spring, but it would be great if that
dependency could be inverted. Maybe just by defining secureCatalog in
applicationSecurityContext.xml? so that if anyone needs to do
something different it can treat security as a cross cutting concern
instead of a hard dependency of main?
2c./
Gabriel
On Wed, Nov 9, 2011 at 3:20 PM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
being trivial).
Opinions?
Ing. Andrea Aime
Tech lead
RSA(R) Conference 2012
Save $700 by Nov 18
Register now
http://p.sf.net/sfu/rsa-sfdev2dev1
Geoserver-devel mailing list
Gabriel Roldan
OpenGeo - http://opengeo.org
Works for me. If its just the filter classes then I think main is appropriate… if other stuff like the schema files, etc… need to be moved out then perhaps a new module is more appropriate… web-app-base or something.
On Wed, Nov 9, 2011 at 11:20 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
I’d like to propose a little modifications to the web-app module
  • for some reason during the deploy of releases the jar ends up
  • the web-app contains some crucial classes (filters), so it’s needed,
    I know, one could use maven exclusion mechanism, but it’s imho
being trivial).
Opinions?
Ing. Andrea Aime
Tech lead
Save $700 by Nov 18
Register now
Justin Deoliveira
related but not relevant: i spent a little time some weeks ago playing with moving the dependency information for community modules back into the poms (instead of whitelisting the dependencies again in release/ext-*.xml). I only did it for the CSS module but the approach is all in the POM and could easily (straightforward, but not automatic) be applied to the other community modules and the supported extensions.
https://github.com/dwins/geoserver/compare/master…assembly
The upshot is that “mvn package” in any community module (set up this way) would produce the zip archive with only runtime dependencies, not provided ones (and we’d just mark core geoserver modules as ‘provided’). cd community && mvn package -PcommunityRelease aggregates those zip files in a single handy directory too. mvn package -Pcss,printing would do the same for just css and printing (for example.)
Eventually I think “going with the flow” of maven a bit more could assist in making the web module more flexible but I haven’t looked at what that would imply.
David Winslow
OpenGeo - http://opengeo.org/
On Wed, Nov 9, 2011 at 2:00 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
A big +1.
main’s applicationContext.xml, depends on accessRulesDao, defined in
I don’t know much about spring, but it would be great if that
2c./
Gabriel
being trivial).
Opinions?
Ing. Andrea Aime
Tech lead
Save $700 by Nov 18
Register now
Gabriel Roldan
Save $700 by Nov 18
Register now
On Wed, Nov 9, 2011 at 8:00 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
A big +1.
Nice thanks.
We could move that bean into applicationSecurityContext.xml, but
you'll still have to declare it somewhere otherwise you'll get no
security at all (actually, worse, you won't get any catalog at all, since
that's the top-most wrapper).
Another observation, how do you override the applicationSecurityContext.xml
built into main?
Redefining all the beans in another context file lets you be pray of the
iteration order i the classpath, sometimes the new context file will win,
other times not, depending on the container, filesystem and java version
Ing. Andrea Aime
Tech lead
On Wed, Nov 9, 2011 at 4:36 PM, Andrea Aime
A big +1.
Nice thanks.
yeah, of course. The thing is to just have the option.
built into main?
in web.xml:
<param-value>classpath*:/applicationContext.xml
classpath*:/geonodeApplicationSecurityContext.xml</param-value>
Ing. Andrea Aime
Tech lead
Gabriel Roldan
On Wed, Nov 9, 2011 at 8:29 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
something.
You are bringing up an interesting point about the schemas.
The src/main/webapp looks as follows:
Afaik there is no reason for any of these to stay in web-app, we could keep
any one of them in the classpath and publish them from the classpath
via a FilePublisher/Wicket resource like mechanism (a new ClasspathPublisher)?
If we go down that path we could have:
  • wms host the openlayers stuff, the wms schemas, the sld schemas
  • wfs host the wfs schemas
  • wcs host the wcs schemas
  • wps same
  • main host xlink, ows, filter, gml and validate, as well as the j_spring* files
This would leave in web-app just the web.xml and the empty
dispatcher-servlet.xml files
How does this sound?
Ing. Andrea Aime
Tech lead
On Thu, Nov 10, 2011 at 11:34 AM, Andrea Aime <andrea.aime@anonymised.com…1268…> wrote:
Hey, I have this approach a shot, seems to work like a charm.
I won’t give you a patch, moving all the schema files is making for a very large changeset,
but have a look at the work in progress on java files and app context files in the
attached one.
What do you think? Seems rather straightforward to me, and increases the server modularity
quite a bit, giving also modules the ability to publish whatever on the webapp right out
of the classpath (say, for example, that you need a specific javascript library, more schemas
or something like that)
Ing. Andrea Aime
Tech lead
(attachments)
classpathPublished.patch (14.1 KB)
On Thu, Nov 10, 2011 at 3:34 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
something.
  • wps same
Very nice! I like it :slight_smile:
Ing. Andrea Aime
Tech lead
Justin Deoliveira
On Thu, Nov 10, 2011 at 7:04 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Nov 10, 2011 at 11:34 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
attached one.
Sounds good to me. Looked over the patch… i think it might not include all changes? For instance AbstractURLPublisher… i can’t find that class anywhere but it seems the patch contains modifications to it… or am I crazy? :slight_smile:
Ing. Andrea Aime
Tech lead
Justin Deoliveira
Hey Andrea,
as Justin mentioned it looks like you missed at least one commit on
the diff, I guess that could be just because the previous commit
contained all the file moves, so no worries. That said, the purpose
and working is pretty clear and it looks like a great way of
approaching the issue to me.
Have my +1.
Gabriel.
On Thu, Nov 10, 2011 at 4:30 PM, Justin Deoliveira <jdeolive@anonymised.com.1501…> wrote:
Doh sorry, rediffed. I still omitted all the schema movements around, just
the code and app context changes
Ing. Andrea Aime
Tech lead
(attachments)
classpath.patch (17.1 KB)
On 11 November 2011 07:04, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Nov 10, 2011 at 4:30 PM, Justin Deoliveira <jdeolive@anonymised.com>
server modularity
webapp right out
Sounds good to me. Looked over the patch... i think it might not include
all changes? For instance AbstractURLPublisher... i can't find that class
anywhere but it seems the patch contains modifications to it... or am I
Ing. Andrea Aime
Tech lead
Save $700 by Nov 18
Register now
I think this is a great idea and will make a huge difference for
custom packaging. We haven't come up against this too often, but it's
a maintenance nightmare every time.
If you're collecting +1's, you can have mine.
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
