[Geoserver-devel] Revamping GSIP-45
We'd like to revamp the GSIP-45
http://geoserver.org/display/GEOS/GSIP+45+-+Moving+GeoServer+model+in+a+standalone+module
Here's the related R'n'D page:
http://geoserver.org/display/GEOS/Resource+*Info+beans+refactoring
There have already been some discussion about it, and the proposed
implementation changed after some ideas from Justin:
http://www.mail-archive.com/geoserver-devel@lists.sourceforge.net/msg09231.html
This refactoring is quite important for better supporting integration with
external application. Please note that also the rest-client community module
had to reimplement its own model, mirroring the existing one.
   Ciao,
   Emanuele
Ing. Emanuele Tajariol
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
mob: +39 3477895230
http://geo-solutions.blogspot.com
How does it relate to GSIP-52? http://geoserver.org/display/GEOS/GSIP+52±+Refactor+out+DAO+for+Catalog+and+Configuration
It might be easier to just make a new GSIP, that refers to 52, and proposes with regards to that, and addresses everything brought up in the gsip 45 email thread.
And what’s the timeframe you would do the work in? I was hoping we’d be moving to RC1 the first week of January, and this sounds like a potential major change that would push that back? Or did you want to target 2.2.x?
Justin’s on vacation, but I think it’s pretty important that he sound in. Hopefully he has some time to respond.
On Wed, Dec 22, 2010 at 10:35 AM, Emanuele Tajariol <etj@anonymised.com> wrote:
We’d like to revamp the GSIP-45
http://geoserver.org/display/GEOS/GSIP+45±+Moving+GeoServer+model+in+a+standalone+module
Here’s the related R’n’D page:
Ciao,
Emanuele
fax: +39 0584962313
mob: +39 3477895230
Learn how Oracle Real Application Clusters (RAC) One Node allows customers
to consolidate database storage, standardize their database environment, and,
should the need arise, upgrade to a full multi-node Oracle RAC database
without downtime or disruption
http://p.sf.net/sfu/oracle-sfdevnl
Geoserver-devel mailing list
I can’t quite remember where the idea left off but I remember coming to a good consensus. The highlights of which from memory are:
  • a pure refactoring with zero behavior changes
  • the new model model interfaces maintain and identical structure to the current ones except they are 1) prefixed with “I” and 2) all dependencies for “resource loading” are removed
  • the impl classes are factored out along with the interfaces
  • the existing interfaces implement the new ones and there should be any client code changes
Anything I am missing? With that the impact in terms of code base should be minimal. A new module called “api” (or something) and changes to the core config and catalog to implement the new interfaces and extend the new implementation classes.
-Justin
Ciao,
Emanuele
fax: +39 0584962313
mob: +39 3477895230
Geoserver-devel@anonymised.comt
Ciao Chris,
as Justin has already pointed out, this will be a pure refactoring with zero
behavior changes, so I guess the description in the existing R'n'D and GSIP
pages should be enough.
We are planning to release these changes in 2.2.x , so the RC1 will not be
affected.
   Ciao,
   Emanuele
http://geoserver.org/display/GEOS/GSIP+52+-+Refactor+out+DAO+for+Catalog+an
d+Configuration
email thread.
And what's the timeframe you would do the work in? I was hoping we'd be
Justin's on vacation, but I think it's pretty important that he sound in.
<etj@anonymised.com>wrote:
> Hi all,
>tandalone+module Here's the related R'n'D page:
>1.html
> with external application. Please note that also the rest-client
> community module
> Ciao,
> Emanuele
fax: +39 0584962313
mob: +39 3477895230
Ciao Justin,
the planned changes are exactly the ones you cited.
   Emanuele
Alle 22:52:43 di mercoledì 22 dicembre 2010, Justin Deoliveira ha scritto:
I can't quite remember where the idea left off but I remember coming to a
* a pure refactoring with zero behavior changes
* the new model model interfaces maintain and identical structure to the
  1) prefixed with "I" and
  2) all dependencies for "resource loading" are removed
* the impl classes are factored out along with the interfaces
* the existing interfaces implement the new ones and there should be any
client code changes
minimal. A new module called "api" (or something) and changes to the core
-Justin
>and+Configuration
> <etj@anonymised.com> wrote: Hi all,
>1.html
> community module had to reimplement its own model, mirroring the existing
> one.
> Ciao,
> Emanuele
> GeoSolutions S.A.S.
> Italy
> fax: +39 0584962313
> mob: +39 3477895230
>----- Learn how Oracle Real Application Clusters (RAC) One Node allows
> customers to consolidate database storage, standardize their database
> environment, and, should the need arise, upgrade to a full multi-node
> Oracle RAC database without downtime or disruption
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
fax: +39 0584962313
mob: +39 3477895230
Dear All,
just to clarify a little bit.
In principle the changes should be minimal as pointed out by justin, although I don’t think we will have enough time to do this within the timeframe of the 2.1, therefore I wold emanuele to shoot for the 2.2 and coordinate with justin on the db work.
Simone.
Ing. Simone Giannecchini
Founder
fax: +39 0584962313
mob: +39 333 8128928
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
On Fri, Dec 24, 2010 at 11:31 AM, Emanuele Tajariol <etj@anonymised.com1268…> wrote:
Ciao Chris,
behavior changes, so I guess the description in the existing R’n’D and GSIP
affected.
Ciao,
Emanuele
d+Configuration
email thread.
tandalone+module Here’s the related R’n’D page:
1.html
community module
Ciao,
Emanuele
fax: +39 0584962313
mob: +39 3477895230
Ah cool, 2.2.x sounds great.
C
On Fri, Dec 24, 2010 at 2:55 AM, Simone Giannecchini <simone.giannecchini@anonymised.com268…> wrote:
Dear All,
Simone.
Founder
fax: +39 0584962313
On Fri, Dec 24, 2010 at 11:31 AM, Emanuele Tajariol <etj@anonymised.com> wrote:
Ciao Chris,
affected.
Ciao,
Emanuele
d+Configuration
email thread.
1.html
community module
Ciao,
Emanuele
fax: +39 0584962313
mob: +39 3477895230
