Doing a bit of research to see what is needed out of a 1.4.M0 review - and thought I should share concerns raised thus far.
Goal:
- proposal for tonights GeoServer meeting
Concerns:
- division between module support (platform? runtime?) and the existing main module (capture spring dependencies and support classes separate from the support classes for OWS and configuration)
- use of spring context - is there once big flat context for the entire module system?
- provision of support classes to gather up annotated classes from modules (um is that Java 5 only? oh wait a uniformly named file in each module would do the trick)
- module naming to prevent collisions (recommendation of org.vfny.geoserver.xxModuleName may conflict with maven conventions?)
- docs on how things are wired up (actually a diagram request, possible BeanDoc)
Actions:
- review spring xml files and add notations for "BeanDoc"
Concerns:
Separation into:
- main - module support, sucks spring dependencies together in a pom.xml, with docs and utility classes as required (see below...)
- data - open web service support (requires a config)
No, each module has a context.
This is needed if two modules want share the same database, and is the motivation for utility classes in main. The Java 5 part seems to be not important.
Was a problem with maven eclipse:eclipse - rename modules to prevent conflicts.
