[Geoserver-devel] RTree spatial index support ready
as promised I’ve put together a pull request implementing rtree support for geopackages:
https://github.com/geotools/geotools/pull/1705
The speed up if of course quite large. However, the distance between geopackages and
shapefiles have not been filled yet, I’ve made two quick benchmarks repeating the same map request on my computer with multiple threads, on the tiger roads data set used for the FOSS4G 2008 benchmark (all Texas roads, 3 millions of them):
  • Trying to render the entire dataset takes 1 second for shapefile and 24 seconds for geopackage, both working off a hot file system cache
  • Trying to render a small portion of it (small town in view) is blinking fast for both, running a benchmark shows something like 130 requests per second on geopackage, and 150 for shapefile
    One of the major advantages of shapefile is that it has the “simplify on bbox” functionality still missing from geopackage.
However, I cannot implement it as part of SQL, will have to redesign a bit the JDBC data store to allow creation of “attribute reader” objects created once and used used over and over
to get there with good performance (and in the process, remove one thread local hack from the postgis store).
Not sure if/when this will be done, but for sure not in time for 2.12.0
That said, access to shapefile is raw and optimized, access to geopackage is mediated by a JDBC driver and needs to cross the JNI
barrier, so I don’t expect the geopackage store to ever match the shapefile performance… but it should be possible to make it
get closer on the “render my whole giant dataset” use case.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
