[Geoserver-devel] SDE in GeoServer: which module has the right dependency names?
I'm looking into the sdeLibs profiles contained in the
sde extension and in the web-app modules.
The one in sde extension says:
<profile>
          <id>sdeLibs</id>
          <dependencies>
             <dependency>
                <groupId>com.esri</groupId>
                <artifactId>jsde_sdk</artifactId>
                <version>${sde.version}</version>
             </dependency>
             <dependency>
                <artifactId>jsde_jpe_sdk</artifactId>
             </dependency>
          </dependencies>
       </profile>
whilst web-app contains:
<profile>
       <id>arcsde</id>
       <dependencies>
         <dependency>
           <groupId>org.geoserver.extension</groupId>
           <artifactId>arcsde</artifactId>
           <version>2.0.2-SNAPSHOT</version>
         </dependency>
       </dependencies>
     </profile>
     <profile>
       <id>sdeLibs</id>
       <dependencies>
         <dependency>
         </dependency>
         <dependency>
         </dependency>
         <dependency>
           <groupId>com.ibm.icu</groupId>
           <artifactId>icu4j</artifactId>
           <version>3.4.4</version>
         </dependency>
       </dependencies>
     </profile>
Notice how the jpe artifact ides are different.
Plus, is there any need to duplicate the sdeLibs profile?
It's used in conjuction with the arcsde profile so in theory
the declarations inside extensions/arcsde/pom.xml should
be sufficient, no?
The result of the current situation is that the projects
generated look for both versions of the jpe jar.
Andrea Aime
OpenGeo - http://opengeo.org
I just committed a patch to extension/arcsde/pom.xml so the sdeLibs profile in both the extension and web/app names it the same.
But it seems I can't get rid of the sdeLibs profile declaration in web/app though that's what I first thought too.
If I do, running mvn jetty:run -Parcsde,sdeLibs does not work, I get a NoClassDefFoundError: com/esri/sde/sdk/client/SeConnection
Do you know if it is possible to inherit the sdeLibs profile from the extension at all when running jetty? and if so, how?
Gabriel
Andrea Aime wrote:
<profile>
          <id>sdeLibs</id>
          <dependencies>
             <dependency>
             </dependency>
             <dependency>
             </dependency>
          </dependencies>
       </profile>
<profile>
       <id>arcsde</id>
       <dependencies>
         <dependency>
         </dependency>
       </dependencies>
     </profile>
     <profile>
       <id>sdeLibs</id>
       <dependencies>
         <dependency>
         </dependency>
         <dependency>
         </dependency>
         <dependency>
         </dependency>
       </dependencies>
     </profile>
be sufficient, no?
Gabriel Roldan
If I do, running mvn jetty:run -Parcsde,sdeLibs does not work, I get a NoClassDefFoundError: com/esri/sde/sdk/client/SeConnection when trying to access an sde raster, or a disabled datastore at startup
Gabriel
Andrea Aime wrote:
<profile>
          <id>sdeLibs</id>
          <dependencies>
             <dependency>
             </dependency>
             <dependency>
             </dependency>
          </dependencies>
       </profile>
<profile>
       <id>arcsde</id>
       <dependencies>
         <dependency>
         </dependency>
       </dependencies>
     </profile>
     <profile>
       <id>sdeLibs</id>
       <dependencies>
         <dependency>
         </dependency>
         <dependency>
         </dependency>
         <dependency>
         </dependency>
       </dependencies>
     </profile>
be sufficient, no?
Gabriel Roldan
Yeah I guess this won't work since when running local in the web/app module there is no way for maven to activate the profile from extensions/arcsde. I guess this means that maven won't active profiles unless the module is in the reactor, and not just referenced from the local maven repository. So this is an issue with all extensions that have a profile that activate additional libs like oracle and sqlserver.
Gabriel
Andrea Aime wrote:
<profile>
          <id>sdeLibs</id>
          <dependencies>
             <dependency>
             </dependency>
             <dependency>
             </dependency>
          </dependencies>
       </profile>
<profile>
       <id>arcsde</id>
       <dependencies>
         <dependency>
         </dependency>
       </dependencies>
     </profile>
     <profile>
       <id>sdeLibs</id>
       <dependencies>
         <dependency>
         </dependency>
         <dependency>
         </dependency>
         <dependency>
         </dependency>
       </dependencies>
     </profile>
be sufficient, no?
Justin Deoliveira
