[Geoserver-devel] search locations question
After a bit of encouragement this week I am almost ready to submit the Managed File API proposal.
Before I do I wanted a to ask for the historical background on GeoServerResourceLoader “search locations”.
Reviewing the code we end up with the following:
  1. base directory (determined using lookupGeoServerDataDirectory)
  2. base directory / data (is this for backwards compatibility?)
  3. application context / WEB-INF
  4. application context /
  5. absolute file references: the API supports the use of find( parent, location ) - which performs a check for absolute file references. I cannot find much evidence that this is used - code such as security or style pass in the appropriate data directory folder.
Search locations recorded as a Set so no order is assumed when searching (so using search locations to “override” data directory settings would not work)
Jody Garnett
So here is an example:
Search Location base dir: ./target/default8117989407937039007data
Search Location additional dir: ./target/default8117989407937039007data
Search Location additional dir: ./target/default8117989407937039007data/data
Search Location additional dir: /Users/jody/java/geoserver/jive/src/main/./target/default8117989407937039007data/WEB-INF
Jody Garnett
On 20 February 2014 at 12:58:59 pm, Jody Garnett (jody.garnett@anonymised.com) wrote:
Jody Garnett
Hi Jody,
I believe the search location business was created fully by Justin.
At least I have no clue why we are searching more locations than
just the data directory
On Thu, Feb 20, 2014 at 11:16 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea:
I just did not want to hurt anyones feelings (or production stability) by removing useful functionality. So far the only deal breaker I can find is some security code that accesses WEB-INF/web.xml
Well we will see what Justin says, but I feel simplification (although rare for GeoServer) may be in order.
Jody Garnett
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Yes I believe it’s obsolete now. I believe we might have been using a while back to load resources from WEB-INF but don’t think that is the case any longer. So yeah, thinking it is probably something that can be killed.
On Thu, Feb 20, 2014 at 3:55 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Thanks Andrea:
Jody Garnett
On 20 February 2014 at 9:26:20 pm, Andrea Aime (andrea.aime@anonymised.com) wrote:
Hi Jody,
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
Jody Garnett
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Justin, I was indeed able to remove dependence on search locations, tests pass, etc…
Jody Garnett
On Fri, Feb 21, 2014 at 3:35 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Thanks Andrea:
Jody Garnett
Hi Jody,
Justin Deoliveira
@j_deolive
Jody Garnett
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
