Hello folks,
I create a shpfile Datastore then publish it.
I seed the pbf tiles using GWC,but tiles number is less than normal ,which meaning lacking amount of the tiles.
I have installed vectortiles plugin and gwc-sqlite plugin.
But however I use “File BlobStore” or “MBTiles BlobStore” It generated the same wrong count of tiles.
The geoserver log did not indicate any useful infomation which did not include ERROR log information.
I have set all log Level.They are the same result.
My configuraion of “Metatiling factors” is 4X4.
When I changed this configuration to 1X1,It can generate the normal and right tiles.
I have test this case in 2.22.0 and 2.23.0 ,the problem cause the same.
Any clues appreciate.
Best regurds.
George.
