(whoops, noticed that I answered only privately, sending to ml as well):
Geoserver is already at a stupid 110MB size… 3.5MB more is like a 3% increase, not much
At the same time, this is exactly how it grows… Little by little over the years.
So, I’d cast a “zero” vote on this.
I was looking recently on how to put GS on a diet and one big contributor to size is the SQLite JDBC driver, which packs native libs for a large variety of platforms. If it was doctored to remove support for the less common ones, it would shrink by a few MB for sure. Just thinking out loud.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
