[Geoserver-devel] Shell issues with the startup/shutdown shell scripts?
As part of the QA process for the OSGEO LiveDVD some one has pointed
out that the use of export FOO=bar is a bashism that won't work with
the default Ubuntu and Debian default sh (dash). The suggested fix is
to use FOO=bar; export FOO. The other alternative is to explicitly
call /bin/bash at the top of the script instead of /bin/sh.
However I'm running on Ubuntu currently and I don't see any problems
(though I have JAVA_HOME already set). Has anyone else seen any
problems with exports in the shell scripts?
Ian
Ian Turton
out that the use of export FOO=bar is a bashism that won’t work with
However I’m running on Ubuntu currently and I don’t see any problems
Definitely works in Ubuntu, I guess Debian might be stricter
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
On Sun, Jun 26, 2011 at 6:04 PM, Andrea Aime <andrea.aime@anonymised.com.1268…> wrote:
Btw, see here:
https://help.ubuntu.com/community/EnvironmentVariables
Ing. Andrea Aime
Tech lead
