Hi Devs,
I'm trying to create an image mosaic here from a directory of some time
based Ascii Grid files (.asc files in epsg:28992).
Whatever I try, debugging in latest master here, I fail to create an
valid index shp in the directory.
Here: http://duif.net/asctest.zip you can download a zip with 4 asc
files (plus an indexer.properties and timeregex.properties; start
Geoserver with -Dorg.geotools.shapefile.datetime=true to be able to
handle time in shapes)) , but upon trying to create a mosaic store from
that there is just 1 record in the shape file.
I see:
29 Aug 21:25:14 DEBUG [gce.imagemosaic] - Granule acceptor
org.geotools.gce.imagemosaic.acceptors.HomogeneousCRSAcceptor rejected
the granule being
processed/tmp/ppp/d0864a2d-a11f-4081-854a-c35bd85eec01-2-201806051540.asc
29 Aug 21:25:14 DEBUG [gce.imagemosaic] - Done with file
in the log, but it is not clear to me why this is.
Registring the layer from that store is fine, but it is impossible to
retrieve an wms image from it. Image shows: Failed to load granule file:
<then the right path to a valid asc file>. Note that an individual asc
store loads succesfully.
Below is stracktrace (geoserverdev level)
Thanks for any pointers
Richard Duivenvoorde
ps I'm aware that translating them to geotiff is the preferred way, but
in this case easiest would be if we can keep it asc files.
ps2 I did that, and then the index is filled ok (and all is working)
Stracktrace:
Aug 30, 2018 9:42:29 AM
it.geosolutions.imageio.plugins.arcgrid.AsciiGridsImageReader setInput
SEVERE: closed
java.io.IOException: closed
at
javax.imageio.stream.ImageInputStreamImpl.checkClosed(ImageInputStreamImpl.java:110)
at
it.geosolutions.imageio.stream.input.FileImageInputStreamExtImpl.seek(FileImageInputStreamExtImpl.java:283)
at
javax.imageio.stream.ImageInputStreamImpl.reset(ImageInputStreamImpl.java:806)
at
it.geosolutions.imageio.plugins.arcgrid.AsciiGridsImageReader.setInput(AsciiGridsImageReader.java:262)
at
it.geosolutions.imageio.plugins.arcgrid.AsciiGridsImageReader.setInput(AsciiGridsImageReader.java:882)
at
com.sun.media.jai.imageioimpl.ImageReadCRIF.getImageReader(ImageReadCRIF.java:250)
at
com.sun.media.jai.imageioimpl.ImageReadCRIF.create(ImageReadCRIF.java:277)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
at
javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
at
it.geosolutions.jaiext.ConcurrentOperationRegistry.invokeFactory(ConcurrentOperationRegistry.java:576)
at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
at javax.media.jai.RenderedOp.getWidth(RenderedOp.java:2179)
at org.geotools.coverage.grid.io.imageio.ReadType$2.read(ReadType.java:152)
at
org.geotools.gce.imagemosaic.GranuleDescriptor.loadRaster(GranuleDescriptor.java:1229)
at org.geotools.gce.imagemosaic.GranuleLoader.call(GranuleLoader.java:108)
at org.geotools.gce.imagemosaic.GranuleLoader.call(GranuleLoader.java:38)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at
org.geotools.gce.imagemosaic.granulecollector.BaseSubmosaicProducer.acceptGranule(BaseSubmosaicProducer.java:434)
at
org.geotools.gce.imagemosaic.granulecollector.DefaultSubmosaicProducer.accept(DefaultSubmosaicProducer.java:75)
at
org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.visit(RasterLayerResponse.java:364)
at
org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.getGranuleDescriptors(CachingDataStoreGranuleCatalog.java:193)
at
org.geotools.gce.imagemosaic.RasterManager.getGranuleDescriptors(RasterManager.java:1338)
at
org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:677)
at
org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:612)
at
org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:580)
at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1329)
at
org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:946)
at
org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:923)
at
org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:152)
at
org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:246)
at
org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:234)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readSingleCoverage(GridCoverageReaderHelper.java:637)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverage(GridCoverageReaderHelper.java:213)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverages(GridCoverageReaderHelper.java:238)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:875)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:824)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1037)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:353)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:269)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:1)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:720)
at org.geoserver.wms.GetMap.run(GetMap.java:300)
at org.geoserver.wms.GetMap.run(GetMap.java:123)
at
org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:251)
at
at
at
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:333)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
at
org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:38)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:59)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:1)
at
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:72)
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:1)
at
at
org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:50)
at
at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:213)
at com.sun.proxy.$Proxy33.getMap(Unknown Source)
at
at
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:877)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:264)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:174)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
at
org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:141)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263)
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90)
at
at
org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:79)
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
at
at
at
org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at
org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at
org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at
org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at
org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at
org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at
org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at
org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at
org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at
org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at
org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at
org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:748)
Aug 30, 2018 9:42:29 AM org.geoserver.GeoserverInitStartupListener$1
errorOccurred
INFO: One factory fails for the operation "ImageRead"
java.lang.reflect.InvocationTargetException
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: java.lang.IllegalArgumentException: Unable to parse the
header for the provided input
at
it.geosolutions.imageio.plugins.arcgrid.AsciiGridsImageReader.setInput(AsciiGridsImageReader.java:266)
at
at
at
... 151 more
Caused by: java.io.IOException: closed
at
at
at
at
... 154 more
30 Aug 09:42:29 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the
fast path
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:355)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.geoserver.platform.ServiceException:
org.geotools.data.DataSourceException: Unable to create this mosaic
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1201)
at
... 114 more
Caused by: org.geotools.data.DataSourceException: Unable to create this
mosaic
at
org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:759)
at
at
at
at
at
at
at
at
at
at
at
at
at
... 115 more
Caused by: java.io.IOException: java.util.concurrent.ExecutionException:
org.geotools.gce.imagemosaic.GranuleLoadingException: Failed to load
granule
file:/home/richard/z/18/rivm/0821_netcdf/puff2/d0864a2d-a11f-4081-854a-c35bd85eec01-2-201806052040.asc
at
org.geotools.gce.imagemosaic.granulecollector.BaseSubmosaicProducer.collectGranules(BaseSubmosaicProducer.java:224)
at
org.geotools.gce.imagemosaic.granulecollector.BaseSubmosaicProducer.createMosaic(BaseSubmosaicProducer.java:388)
at
org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.produce(RasterLayerResponse.java:427)
at
org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.access$600(RasterLayerResponse.java:279)
at
org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:681)
... 129 more
Caused by: java.util.concurrent.ExecutionException:
granule
at java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.util.concurrent.FutureTask.get(FutureTask.java:192)
at
org.geotools.gce.imagemosaic.granulecollector.BaseSubmosaicProducer.collectGranules(BaseSubmosaicProducer.java:121)
... 133 more
Caused by: org.geotools.gce.imagemosaic.GranuleLoadingException: Failed
to load granule
at org.geotools.gce.imagemosaic.GranuleLoader.call(GranuleLoader.java:112)
at
at
at
at
at
at
... 129 more
Caused by: java.lang.NullPointerException
at
org.geotools.gce.imagemosaic.GranuleDescriptor.loadRaster(GranuleDescriptor.java:1307)
... 137 more
30 Aug 09:42:30 DEBUG [org.geoserver.filters] - Not compressing output
for mimetype: image/jpeg
[org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1]
- SecurityContextHolder now cleared, as request processing completed
