On Wed, Oct 20, 2010 at 4:39 PM, <christian.mueller@anonymised.com> wrote:
http://geoserver.org/display/GEOS/GSIP+54+Upgrade+Geoserver+security+to+Spring+Security+2.0
If one reads the proposal he might think GeoServer uses its own
authentication implementation, however
that is not true, it uses Acegi, which is the old Spring Security,
however it does so in a way that is not
pluggable and that should be amended.
Also, the proposal talks about "security" generically, and at one
point about authentication/authorization.
I'm +1 on making the authentication mechanism be pluggable and use
Spring Security 2.0,
but not on making the authorization use Spring Security instead: the
authorization should be eventually
made more pluggable, but I find the Spring Security way of doing
authorization quite obscure.
For both authentication and authorization I would like to see a design
of how you want to modify the
code to make it pluggable.
I'm +1 on using Spring Security 2.0, however that by itself does not
make much of a GSIP, I don't want
for people to think that any implementation using Spring Security 2.0
will be accepted because
of the vote on the GSIP: a specific design will have to be provided
and voted separately.
Christian
This message was sent using IMP, the Internet Messaging Program.
Nokia and AT&T present the 2010 Calling All Innovators-North America contest
Create new apps & games for the Nokia N8 for consumers in U.S. and Canada
$10 million total in prizes - $4M cash, 500 devices, nearly $6M in marketing
Develop with Nokia Qt SDK, Web Runtime, or Java and Publish to Ovi Store
http://p.sf.net/sfu/nokia-dev2dev
Geoserver-devel mailing list
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
