following up a report of GeoServer creating thousands of http sessions
during "normal" operation I've built a tool to investigate the session
creations and a patch that solves the session creations I've noticed.
The tool is a servlet filter that wraps the HttpServletResponse and
logs the full stack trace of every call forcing the creation of a http
session. It is included in this patch:
http://jira.codehaus.org/browse/GEOS-4478
About the tool, it's quite handy in that it would allow someone else
to also do this kind of debugging, on their own servers.
I'm just undecided on how to integrate it:
a) ship it in the code, but comment out its declaration in web.xml
Whoever needs it just had to hand modify the web.xml to activate it
b) ship it in the code and have it statically declared in the web.xml,
and use a system variable to actually make it wrap the servlet
request (otherwise make it a no-op)
c) ship it and have it always on, any session creation outside of
the web UI is something we want to be informed of asap anyways
I'm tempted to go c), even when wrapping the tool is quite light
unless there is indeed a session creation going on...
how do people feel about this?
Can someone double check/review the patch at
The other part of the work is the actual fix, using the tool I've found
a couple of unexpected session creations, both due to the Spring Security
integration not behaving quite like I hoped:
http://jira.codehaus.org/browse/GEOS-4477
The patch fixes the issues I've seen and should result in greater
scalability for applications that are using secured data layers and
the "www" folder.
However the testing I've made is quite on the light side (checked with some
secured layers)... we'd need someone heavily using security to confirm the
changes are not breaking anything else. Any takers?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 333 8128928
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
