[Geoserver-devel] Starting an stable GeoServer release train early
Hello everyone,
I asked last meeting if I could create an additional stable release for GeoCat Customers (along side the maintenance release scheduled for June 18th).
If you have any changes to get in please let me know. I am going to be pretty focused and not hunting down open PRs like normal.
Jody Garnett
The first release has left the station:
Anyone wishing to provide preflight testing the artifacts are here: https://build.geoserver.org/view/release/job/geoserver-release/ws/distribution/2.23.6/
Blog post is also ready for review as a pull-request: https://github.com/geoserver/geoserver.github.io/pull/199
Peter do you wish to make 2.24.4 next? Or is the coast clear for 2.25.2 …
Jody Garnett
Jody Garnett
Thank you Jody
Yes, I had intended to start with 2.24.4 early next week, but since there are no open PRs on the maintenance branch, I can start with it now.
Peter
GeoServer PSC
AWS Solutions Architect
https://github.com/petersmythe
Jody Garnett
Jody Garnett
GeoServer 2.25.2 is ready for preflight testing: https://build.geoserver.org/view/release/job/geoserver-release/144/artifact/distribution/2.25.2
There was a last moment fix if the new Demo Request page (missing wicket header contributions) but it was otherwise uneventful.
The previous https://github.com/geoserver/geoserver.github.io/pull/199 now covers both releases.
Jody Garnett
Peter
GeoServer PSC
Jody Garnett
Jody Garnett
I made some basic tests on Windows with the bin-zip installation and did not notice any issues. I also clicked through all the demo requests and made some observations.
WFS_getFeatureBetween-1.1.xml fails, I do not understand why.
<ows:Exception exceptionCode=“NoApplicableCode”>
ows:ExceptionTextjava.lang.RuntimeException: Error encoding object to xml-element
Can handle 3 attributes only, index is 3</ows:ExceptionText>
</ows:Exception>
WMS_GetLegendGraphic-SLD.url does not pass validation.
org.geotools.data.ows.URLCheckerException: Evaluation Failure: ‘http://localhost:8080/geoserver/www/styles/green.sld’ was not accepted by external URL checks
The WPS aggregate examples do not work, they return
Error 404 Not Found
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…403…>
Lähetetty: lauantai 15. kesäkuuta 2024 19.01
Vastaanottaja: Peter Smythe <gs@…5004…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Starting an stable GeoServer release train early
Jody Garnett
On Jun 14, 2024 at 5:20:27 AM, Peter Smythe <gs@…5004…> wrote:
Thank you Jody
Peter
GeoServer PSC
Jody Garnett
On Jun 12, 2024 at 4:20:22 PM, Jody Garnett <jody.garnett@…403…> wrote:
Hello everyone,
Jody Garnett
Thanks for testing!
Can we test an earlier version to see if this is a regression in the UI or the application? Without CITE tests in our build we always run a higher risk of regression.
Jody Garnett
Testing with 2.25.1:
  • WFS_getFeatureBBOX.url: result
  • WFS_getFeatureBetween-1.0.xml: states.1, states.7, states.9,states.13,…
  • WFS_getFeatureBetween-1.1.xml: Same error message Caused by: java.lang.ArrayIndexOutOfBoundsException: Can handle 3 attributes only, index is 3
This is the same error you found on 2.25.2: The result should only contain the attributes requested, or that are required to filter the content.
The query checks one attribute:
ogc:Filter
ogc:PropertyIsBetween
ogc:PropertyNametopp:LAND_KM</ogc:PropertyName>
ogc:LowerBoundaryogc:Literal100000</ogc:Literal></ogc:LowerBoundary>
ogc:UpperBoundaryogc:Literal150000</ogc:Literal></ogc:UpperBoundary>
</ogc:PropertyIsBetween>
</ogc:Filter>
The query lists three attributes to return:
wfs:PropertyNametopp:STATE_NAME</wfs:PropertyName>
wfs:PropertyNametopp:LAND_KM</wfs:PropertyName>
wfs:PropertyNametopp:the_geom</wfs:PropertyName>
But the results is coming back with 4 values (not sure why) and it fails when trying to store a the additional values in a feature…
From the logs:
Request: getFeature
service = WFS
version = 1.1.0
baseUrl = http://localhost:8080/geoserver/
query[0]:
propertyName[0] = topp:STATE_NAMEpropertyName[0] = topp:LAND_KMpropertyName[0] = topp:the_geom
filter = [ topp:LAND_KM BETWEEN 100000 AND 150000 ]
typeName[0] = {http://www.openplans.org/topp}states
outputFormat = text/xml; subtype=gml/3.1.1
resultType = results
17 Jun. 08:57:44 DEBUG [data.transform] - The original query for feature extraction Query:
feature type: states
filter: [ topp:LAND_KM BETWEEN 100000 AND 150000 ]
[properties: the_geom, STATE_NAME, LAND_KM] has been transformed to Query:
[properties: STATE_NAME, LAND_KM, the_geom]
17 Jun. 08:57:44 ERROR [geoserver.ows] -
at org.geotools.xsd.Encoder.processChildren(Encoder.java:1028)
at org.geotools.xsd.Encoder.encode(Encoder.java:655)
at org.geotools.xsd.Encoder.encode(Encoder.java:553)
at org.geoserver.wfs.xml.GML3OutputFormat.encode(GML3OutputFormat.java:397)
at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:323)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:199)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:1034)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:273)
at org.geotools.feature.simple.SimpleFeatureBuilder.set(SimpleFeatureBuilder.java:259)
at org.geotools.feature.simple.SimpleFeatureBuilder.add(SimpleFeatureBuilder.java:203)
at org.geotools.feature.simple.SimpleFeatureBuilder.addAll(SimpleFeatureBuilder.java:210)
at org.geotools.feature.simple.SimpleFeatureBuilder.addAll(SimpleFeatureBuilder.java:216)
at org.geotools.feature.simple.SimpleFeatureBuilder.build(SimpleFeatureBuilder.java:349)
at org.geotools.data.crs.ReprojectFeatureIterator.next(ReprojectFeatureIterator.java:125)
at org.geotools.data.crs.ReprojectFeatureIterator.next(ReprojectFeatureIterator.java:62)
at org.geoserver.security.decorators.SecuredSimpleFeatureIterator.next(SecuredSimpleFeatureIterator.java:40)
at org.geoserver.security.decorators.SecuredSimpleFeatureIterator.next(SecuredSimpleFeatureIterator.java:19)
at org.geotools.gml2.simple.FeatureCollectionEncoderDelegate.encode(FeatureCollectionEncoderDelegate.java:124)
at org.geotools.xsd.Encoder.processChildren(Encoder.java:1026)
So this needs a new bug report:
Jody Garnett
Same issue with 2.24.4 preflight artifacts so this does not appear to be a new problem
Jody Garnett
Jody Garnett
Version 2.23.5 does not have this issue.
-Jukka-
Lähetetty: maanantai 17. kesäkuuta 2024 20.01
Vastaanottaja: Rahkonen Jukka <jukka.rahkonen@…4189…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net; Peter Smythe <gs@…5004…>
Jody Garnett
ogc:Filter
</ogc:Filter>
From the logs:
Request: getFeature
service = WFS
version = 1.1.0
query[0]:
Jody Garnett
On Jun 17, 2024 at 5:26:59 AM, Rahkonen Jukka <jukka.rahkonen@…4189…> wrote:
</ows:Exception>
Error 404 Not Found
-Jukka Rahkonen-
Kopio: Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Jody Garnett
Thank you Jody
Peter
GeoServer PSC
Jody Garnett
Hello everyone,
Jody Garnett
So here is where we stand:
  • 2.22.x WFS_getFeatureBetween-1-1.xml - no problem
  • 2.23.6 WFS_getFeatureBetween-1-1.xml - no problem
  • 2.24.2 WFS_getFeatureBetween-1-1.xml - failure
  • 2.25.2 WFS_getFeatureBetween-1-1.xml - failure
Bug is reported here https://osgeo-org.atlassian.net/browse/GEOS-11435
Jody Garnett
